Author Topic: Anyone make an EGR block off plate?  (Read 2583 times)
October 02, 2008, 04:10:12 pm
allsierra123
« on: October 02, 2008, 04:10:12 pm »
Or is it something I will need to come up with?
Reply #1October 02, 2008, 04:17:27 pm
« Reply #1 on: October 02, 2008, 04:17:27 pm »
you could check out kerma TDI.
it's not too hard to make though... just get a piece of steel and cut it then drill some holes, and bingo.  you can use the egr line as a template even.
Reply #2October 02, 2008, 04:25:01 pm
allsierra123
« Reply #2 on: October 02, 2008, 04:25:01 pm »
Nice. Wastn sure if it had to be anything special or not.
Reply #3October 02, 2008, 06:50:17 pm
blkboostedtruck
  • 1535
« Reply #3 on: October 02, 2008, 06:50:17 pm »
i might have one? i bought an intake that had one but i welded up the hole because i needed more clearance but i still have the plate left!
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #4October 05, 2008, 03:19:27 pm
blunt
  • 22
« Reply #4 on: October 05, 2008, 03:19:27 pm »
I used a bit of 5mm deep flat bar, cut it to match the shape of the flanges on the egr i removed, drilled it and bolted it straight on to place, piece of cake!
Reply #5October 05, 2008, 11:40:57 pm
commuter boy
  • 277
« Reply #5 on: October 05, 2008, 11:40:57 pm »
Piece of sheet metal for me.  Cut it with some tin snips, filed the edges, drilled a pair of holes and in it went.
