Author Topic: Head gasket needs replacement  (Read 5369 times)
September 25, 2008, 05:06:04 pm
Super T
  • 23
« on: September 25, 2008, 05:06:04 pm »
My headgasket is in need of replacement but when I went to get one I found out its complicated. How do I know what gasket I need without first removing the old one? Car is 1992 Jetta 1.6L TD.
1987 GTI VR6
1992 Jetta TD
Reply #1September 25, 2008, 05:11:58 pm
« Reply #1 on: September 25, 2008, 05:11:58 pm »
Right behind the injection pump there is part of the headgasket that sticks out from between the block and head. It will have either notches in the edge or holes in it. 1,2 or 3. That is what headgasket you need. If it's a 3 hole, it might be incorrect as it is the thickest and lazy people just throw the thickest on to be safe.
Reply #2September 25, 2008, 06:13:49 pm
« Reply #2 on: September 25, 2008, 06:13:49 pm »
When you buy the headgasket it's a great idea to also buy the official Bentley service manual.... it will pay for itself on this one job alone and save you making potentially expensive mistakes.
You'll also need to read up on timing the engine accurately...a dial indicator and adapter will be required.  The service manual has the full procedure.
Reply #3September 25, 2008, 06:39:09 pm
« Reply #3 on: September 25, 2008, 06:39:09 pm »
Gandalf had a Bentley?  :?
Reply #4September 25, 2008, 07:36:08 pm
« Reply #4 on: September 25, 2008, 07:36:08 pm »
isn't that moses?  :lol: for a guy who could part the seas, you'd think he wouldn't need a bentley... but i guess nobody's perfect
straight from the burning bush!!
Reply #5September 25, 2008, 08:24:58 pm
  • 1739
« Reply #5 on: September 25, 2008, 08:24:58 pm »
Quote from: "jtanguay"
EVERYONE needs one..
Reply #6September 25, 2008, 09:04:56 pm
Super T
  • 23
« Reply #6 on: September 25, 2008, 09:04:56 pm »
Thanks for the input. I have a 1 hole head gasket and the car actually came with a Bently manual in the trunk. Someone suggested getting the newer 1.9 metal gasket, good idea?
1987 GTI VR6
1992 Jetta TD
Reply #7September 25, 2008, 09:53:43 pm
Possum79
  • 276
    • http://www.poscarclub.com
« Reply #7 on: September 25, 2008, 09:53:43 pm »
Kinda jackin this thread. I was reading my bentley before about piston protusion. If I spell wrong just guess what I mean Im tired. I want to measure this when we pull apart a motor in the future but I don't understand how exactly to measure it. The dial indicator seems angled and stuff in the pictures, does it have to be or what? Also I dont have the specific tools can I just use a dial indicator on a jig?
Like can I take a super flat piece of steel and measure how thick it is then put it on a cylinder. Then take a dial indicator on one of those magnetic bases and press it down to till it says the thickness of the metal. They just slide the metal out and measure the piston? If that makes sense.
1979 VW Rabbit Diesel L
Reply #8September 26, 2008, 10:13:25 am
TedV
  • 182
« Reply #8 on: September 26, 2008, 10:13:25 am »
and Moses came down from the mountain and said
"I have been given this Bentley manual...
follow these commandments and your car shall live a long and fruitfull life"
 :wink:  :lol:
Reply #9September 26, 2008, 10:35:28 am
Op-Ivy
  • 513
« Reply #9 on: September 26, 2008, 10:35:28 am »
:lol:
Reply #10September 26, 2008, 05:29:24 pm
« Reply #10 on: September 26, 2008, 05:29:24 pm »
Possum79 that should work.
Reply #11September 26, 2008, 08:09:55 pm
Possum79
  • 276
« Reply #11 on: September 26, 2008, 08:09:55 pm »
Thanks Tyler!
Reply #12September 29, 2008, 06:20:42 pm
Super T
  • 23
« Reply #12 on: September 29, 2008, 06:20:42 pm »
Well I have my head gasket in and my timing kit, and injector nozzles are on the way. I'll be very busy on the weekend.
But I have noticed a lot of air bubbles in my fuel lines when I rev the motor. No fuel leaks. But lots of air. One member here said that would be my rough idle problem. How can I track down my source? Removal of the water seperator was mentioned, how is that done?
1987 GTI VR6
1992 Jetta TD
