Author Topic: what size pump head ?  (Read 2438 times)
August 27, 2008, 09:45:18 am
  • 1739
« on: August 27, 2008, 09:45:18 am »
I need to find out what size pump.head would be on a 1.9 l NA diesel. i hope you guys in europe can help.
Reply #1August 27, 2008, 01:26:53 pm
Powered by Spearco
  • 1203
« Reply #1 on: August 27, 2008, 01:26:53 pm »
I've seen on 1.9 na's 8mm and 9mm heads. Don't know if that stock or what.
Josh
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #2August 27, 2008, 03:35:35 pm
snakemaster
  • 405
« Reply #2 on: August 27, 2008, 03:35:35 pm »
the two that i have striped were 9mm 1.9 na  done the gov mod and turned up the fuel and it would pass a stock 1.6 td  :lol:
Reply #3August 27, 2008, 04:35:18 pm
  • 1739
« Reply #3 on: August 27, 2008, 04:35:18 pm »
well i just installed a 10 mm . I had bought an 11mm ,but my guy believes it also needed a TDI  [ or similar ]camplate to work. As i am pressed for time i had to settle for the 10mm. But the fact that they came with a 9 mm then i should be good to go. Mine did come with an 8mm  head and other governor bits to keep the fueling limited.
Reply #4August 27, 2008, 06:27:31 pm
« Reply #4 on: August 27, 2008, 06:27:31 pm »
You don't want a TDI cam plate in an IDI motor.
