what size pump head ?
Topic: what size pump head ? (Read 2448 times)
August 27, 2008, 09:45:18 am
August 27, 2008, 09:45:18 am »
I need to find out what size pump.head would be on a 1.9 l NA diesel. i hope you guys in europe can help.
August 27, 2008, 01:26:53 pm
Powered by Spearco
August 27, 2008, 01:26:53 pm »
I've seen on 1.9 na's 8mm and 9mm heads. Don't know if that stock or what.
Josh
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
August 27, 2008, 03:35:35 pm
snakemaster
August 27, 2008, 03:35:35 pm »
the two that i have striped were 9mm 1.9 na done the gov mod and turned up the fuel and it would pass a stock 1.6 td :lol:
Glenmorangie single highland malt
August 27, 2008, 04:35:18 pm
August 27, 2008, 04:35:18 pm »
well i just installed a 10 mm . I had bought an 11mm ,but my guy believes it also needed a TDI [ or similar ]camplate to work. As i am pressed for time i had to settle for the 10mm. But the fact that they came with a 9 mm then i should be good to go. Mine did come with an 8mm head and other governor bits to keep the fueling limited.
August 27, 2008, 06:27:31 pm
August 27, 2008, 06:27:31 pm »
You don't want a TDI cam plate in an IDI motor.
