Author Topic: Boost gauge location question  (Read 3445 times)
August 23, 2008, 06:22:16 pm
  • 3468
    • McScrubbins Body Wash
« on: August 23, 2008, 06:22:16 pm »
Can I splice the braided line that links the intake to the LDA and throw a pressure gauge right on it?
I have the brass fittings to do it (but not a long enough line for the gauge to go to my dash.
Is this a silly idea?
Will having a long line go from that location to my dash be inaccurate?
LMK what you think!
Reply #1August 23, 2008, 07:24:26 pm
  • 3468
« Reply #1 on: August 23, 2008, 07:24:26 pm »
Ok, so i did it and this it what it loooooks like!
Dunno what im gonna do when i have to close the window though....
In the process of seeing how much boost I could make I destroyed a rad hose. In my view, it had to be changed anyways! It was one of few that i didn't change. Made about 10psi at the top end though. Basically none on the low end... with the fuel screw turned OUT quite a lot. no smoke.
Reply #2August 23, 2008, 07:26:34 pm
  • 3468
« Reply #2 on: August 23, 2008, 07:26:34 pm »
Does anyone know if the oil in that line means anything? It concerns me. Tells me im burning a hefty amount of oil. And does the LDA particularily like that oil?
Reply #3August 24, 2008, 05:46:54 am
burnt_servo
  • 278
« Reply #3 on: August 24, 2008, 05:46:54 am »
you will get a little bit of oil in the line ..... the higher the rpm the engine is run at , the more oil you will find in the line .
99 times out 100  the oil is from the breather tube coming out of the valve cover , nothing really to worry about , unless your having to top up the engine oil on a regular basis , and you can't see any leaks .
where you tapped ito your presure line is about the same spot i used .
as long as you don't pinch or crush the line to the guage , you can go many times longer than the actual distance you will need to have the guage on the dash .
worst case senerio , the guage will read a bit slow to what is actually happening .
1990 jetta , tweaked pump , tweaked turbo , ported head  2.5inch exhaust .
1993 dodge w250 , diesel ... removing the dead moose parts .
Reply #4August 24, 2008, 12:45:09 pm
  • 3468
« Reply #4 on: August 24, 2008, 12:45:09 pm »
awesome! thanks. How do you get yours to the dash? do you drill a hole through the fire wall where the little wireing harness (i guess you could call it) goes through?
Reply #5August 24, 2008, 01:07:56 pm
burnt_servo
  • 278
« Reply #5 on: August 24, 2008, 01:07:56 pm »
i just followed the wiring harnes past the firewall .
Reply #6August 24, 2008, 03:50:07 pm
  • 3468
« Reply #6 on: August 24, 2008, 03:50:07 pm »
Hmmm mine has like a rubber gromet that keeps it all sealed shut... was yours an open hole? or did you pull the gromet off ( i think gromet is the word im looking for?)
Reply #7August 24, 2008, 04:49:31 pm
morefuel
  • 9
« Reply #7 on: August 24, 2008, 04:49:31 pm »
you could also just take a knife make the gromet for the wiring harness a bit larger to accomodate the whose
Reply #8August 24, 2008, 06:50:42 pm
  • 3468
« Reply #8 on: August 24, 2008, 06:50:42 pm »
good idea, i'll do that
Reply #9August 24, 2008, 11:47:16 pm
Op-Ivy
  • 513
« Reply #9 on: August 24, 2008, 11:47:16 pm »
Quote from: "burnt_servo"
x2
The window deal looks impractical  :lol:
PS: Look at all us B.C. folk here eh?
Reply #10August 24, 2008, 11:51:50 pm
  • 3468
« Reply #10 on: August 24, 2008, 11:51:50 pm »
Beauty eh!
yeah the through the windo thing was just to test it out
Reply #11August 25, 2008, 07:19:00 am
burnt_servo
  • 278
« Reply #11 on: August 25, 2008, 07:19:00 am »
Quote from: "Op-Ivy"
i know , it's kind of scarry .....  but have you seen all the vw diesels on the road all of a sudden in the last 2 years in b.c ........
Reply #12August 25, 2008, 10:28:33 am
  • 3468
« Reply #12 on: August 25, 2008, 10:28:33 am »
yeah, and OLD ones too....
I work with someone who has an mk1 jetta, the first turbo diesel model, and it has over 700k on it. two rebuilds? or something... starts better than mine, sounds better than mine, but is a lot slower ^.^
