Author Topic: Running fine, then died, now won't turn over  (Read 6758 times)
August 05, 2008, 06:52:04 am
drshoebocks
  • 39
« on: August 05, 2008, 06:52:04 am »
Here is the story
Caddy was running great, then out of no where it suddenly died coming up to a stop sign.  My immediate fear was timing belt so I pushed it to the side, ran home (which was close) grabbed some tools and took the timing belt cover off to inspect.  The belt looked fine.  Pushed the car home with a neighbor and checked obvious things like making sure it didn't run out of diesel or oil.  Had my girlfriend crank it while I cracked the injectors and diesel is coming out fine and the line from filter to IP has diesel coming through.  Here is the strange part it will crank and start to turn over then die.  If my GF holds the key in the all way to start it will crank over and limp but die as soon as she lets it go.
Oh boy, what should I check next?  Curious about the fuel shutoff solenoid, but I don't know how to inspect.  I assume the IP is fine as fuel is getting to the injectors.  Could it be the injectors them selves?  Could timing have skipped and I just don't know it.
Any and all suggestions are greatly appreciated.
1982 Rabbit Pickup 1.6D NA
Love it, but...
Reply #1August 05, 2008, 08:54:15 am
« Reply #1 on: August 05, 2008, 08:54:15 am »
maybe the IP sucked up a large amount of air?  any bubbles going to the pump?
diesel coming out of each injection line (at the injector-it should be squirting out)
Reply #2August 05, 2008, 09:15:42 am
« Reply #2 on: August 05, 2008, 09:15:42 am »
Try running power straight to the solenoid.
Reply #3August 05, 2008, 09:33:37 am
drshoebocks
  • 39
« Reply #3 on: August 05, 2008, 09:33:37 am »
This is probably elementary, but how do I go about running power directly to the solenoid.
-At the injectors it is splashing out, I wouldn't say it is squirting out.
Love it, but...
Reply #4August 05, 2008, 10:02:29 am
« Reply #4 on: August 05, 2008, 10:02:29 am »
Quote from: "jimfoo"
Exactly. Sounds like a bad ingintion switch.
Take an aligator clip or similar and put on end on the solenoid and one end on the + battery terminal.
Reply #5August 05, 2008, 11:05:43 am
drshoebocks
  • 39
« Reply #5 on: August 05, 2008, 11:05:43 am »
When you are talking about the solenoid, is this the starter solenoid or the fuel shutoff solenoid?
Love it, but...
Reply #6August 05, 2008, 11:25:38 am
« Reply #6 on: August 05, 2008, 11:25:38 am »
Quote from: "drshoebocks"
fuel shut off solenoid.  1 wire going to it and on drivers side of the pump.  there have been cases of the solenoid not getting enough juice, so it opens just enough to give a little fuel, but not enough to keep the motor running...
Reply #7August 05, 2008, 03:11:07 pm
« Reply #7 on: August 05, 2008, 03:11:07 pm »
It could also be that the solenoid crapped out. You should be able to hear a faint click with your ear close to it and cycling power to it on and off
Reply #8August 06, 2008, 04:48:44 am
gigaz2
  • 626
« Reply #8 on: August 06, 2008, 04:48:44 am »
wrenchhead solution: take selenoid out, remove piston and spring, bolt again.
I wouldn't do it unless on an emergency, you won't have any (civilized) way to shut down the engine.
could also be the timing on the pump, somehow jumped a tooth or something, can you check timing?
or, as said before, air in the pump.
Reply #9August 22, 2008, 07:13:36 pm
  • 3468
    • McScrubbins Body Wash
« Reply #9 on: August 22, 2008, 07:13:36 pm »
could the solenoid previously mentioned not getting enough juice cause hard starting? OR is it sort of a yes or no deal? (yes being runing no being not at all)
Reply #10October 13, 2008, 02:19:19 pm
drshoebocks
  • 39
Finally got around to messing with the truck today
« Reply #10 on: October 13, 2008, 02:19:19 pm »
I attached a wire directly from the battery to the fuel solenoid.  I heard a faint click when I attached power to it.  When I did this the glow plugs wouldn't cycle and the red led on the dash was on even if the key wasn't turned.
Regardless with the battery attached to the solenoid directly I still couldn't get it running.  It fires right up and then dies immediately.  If I continue to crank it sort of runs, but as soon as I let go of the key it dies.  I assume this is the starter making it run.  Fuel looks good going from the filter to the pump, it has oil, and I'm not sure what to try next.  I assume I should start going through the timing procedure, which I have never done.  Any advice?
Love it, but...
Reply #11October 13, 2008, 02:35:53 pm
« Reply #11 on: October 13, 2008, 02:35:53 pm »
How long are you cranking it?
If you sucked air in the pump OR if the filter got some air in it some how you have to crank the livin piss out of it to get the air out.
It's not easy but crank crank crank.....
Reply #12October 13, 2008, 02:47:02 pm
drshoebocks
  • 39
« Reply #12 on: October 13, 2008, 02:47:02 pm »
Checked for air leaks both at the filter and at the pump.
Love it, but...
Reply #13October 13, 2008, 03:26:52 pm
dillenger1
  • 777
« Reply #13 on: October 13, 2008, 03:26:52 pm »
what about the ignition?If the spring isnt returning to the run position it would kill power.It would also cause the sarter to run the motor.The bendix mat not be returning.
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #14October 13, 2008, 03:30:53 pm
« Reply #14 on: October 13, 2008, 03:30:53 pm »
If not for the fact he's already tried it by running power directly to the fuel cut off solenoid.
So he's already by passed the ignition.
