General Information
Troubleshooting
Running fine, then died, now won't turn over
Pages:
Topic: Running fine, then died, now won't turn over (Read 6745 times)
Reply #15
October 13, 2008, 03:39:31 pm
dillenger1
Reply #15 on:
October 13, 2008, 03:39:31 pm »
sorry :oops:
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #16
October 13, 2008, 04:15:42 pm
Reply #16 on:
October 13, 2008, 04:15:42 pm »
Try disconnecting the feed and return line from the fuel filter/pump and stick them both into a jerry can. If it works, hook one back up and repeat. If it doesn't work, your fuel system is fine
Reply #17
October 13, 2008, 06:08:34 pm
drshoebocks
User+
Reply #17 on:
October 13, 2008, 06:08:34 pm »
Interesting
But this wouldn't rule out bad timing, correct?
1982 Rabbit Pickup 1.6D NA
Love it, but...
Reply #18
October 13, 2008, 06:34:37 pm
Turbinepowered
Reply #18 on:
October 13, 2008, 06:34:37 pm »
Quote from: "drshoebocks"
Interesting
Tyler's suggestion will help you weed out whether it's your fuel system or something pump/engine related.
If your problem is just bubbles in your fuel system, then the engine will start and run just fine with both hoses in a can of diesel.
If the problem is
not
in your fuel supply system, then the engine will do its normal problem while the fuel lines are sitting poked in a can of diesel.
Reply #19
October 13, 2008, 07:02:33 pm
Reply #19 on:
October 13, 2008, 07:02:33 pm »
It doesn't sound like a timing issue to me. You probably would have heard some really bad sounds as the vavles smoked the pistons, or if the pump was loose it would slowly run worse and worse as it rotated out of time. Or it would surge really bad.
Reply #20
October 14, 2008, 06:45:06 am
drshoebocks
User+
Reply #20 on:
October 14, 2008, 06:45:06 am »
I'll do the fuel check today and report back.
Love it, but...
Pages:
General Information
Troubleshooting
