Author Topic: what would you do  (Read 5563 times)
June 24, 2008, 01:19:04 pm
dokarex
  • 61
what would you do
« on: June 24, 2008, 01:19:04 pm »
I have a 87 Doka with a 1.9TD. Great low end (probably could pull stumps)but I still have the 1.6NA tranny.
I can get a Gas tranny out of an 87 Westy (fire) Would the change in gearing from the diesel tranny to gas one help the top end (currently 110KPH)
Pros
Cons
Etc
1987 1.9TD Doka from Germany gasser DU tranny, fuel turned up, 1.6 LDA pin, boost at 15 psi,egt and boost gauges,stock diesel tach,air filter behind passenger tail light, IC to come
2005 Jetta Wagen TDI
B6200 Kubota Diesel
16ft Freestyle catermeran
16ft Sunray 85HP
Reply #1June 24, 2008, 02:15:33 pm
what would you do
« Reply #1 on: June 24, 2008, 02:15:33 pm »
I dont know about the gears but I took a complete trans out of a gasser for my car.
Reply #2June 24, 2008, 04:18:13 pm
what would you do
« Reply #2 on: June 24, 2008, 04:18:13 pm »
diesels are usually geared taller due to the lower end power.  stock, there isn't much power up top.  you can install a gasser tranny but i doubt you will like it.  look for a turbo diesel tranny and enjoy some good fuel economy :) while taking advantage of the low end grunt of the 1.9
Reply #3June 24, 2008, 06:23:07 pm
what would you do
« Reply #3 on: June 24, 2008, 06:23:07 pm »
I built my aunt a TD and it uses a gas tranny. Just get the ratios and run the numbers. Some are better then others.
Reply #4June 24, 2008, 06:29:20 pm
what would you do
« Reply #4 on: June 24, 2008, 06:29:20 pm »
To wit, the ratios are here:
http://www.scirocco.org/gears/
Reply #5June 24, 2008, 07:17:51 pm
vanagonturbo
  • 639
    • Fine Tuning
what would you do
« Reply #5 on: June 24, 2008, 07:17:51 pm »
Is it a syncro?
I can assure you that you will not be happy with a gas tranny. the ratios will put your rpms even higher. This is not really desirable with a diesel.
Reply #6June 24, 2008, 09:20:44 pm
what would you do
« Reply #6 on: June 24, 2008, 09:20:44 pm »
Mine went from 4000rpm @ 72 mph to
3000rpm @ 72mph
Removed a AWY Diesel trans for a ACN coded gasser trans.
1st gear is just a tad tall but once I'm moving it rocks.
Reply #7June 24, 2008, 09:30:38 pm
vanagonturbo
  • 639
    • Fine Tuning
what would you do
« Reply #7 on: June 24, 2008, 09:30:38 pm »
We are talking Vanagons here ;) Trannies are totally different.
I might also add that the ACN was used on diesel MKIIs as well ;)
Reply #8June 24, 2008, 11:08:31 pm
Quantum TD
  • 1195
what would you do
« Reply #8 on: June 24, 2008, 11:08:31 pm »
Quote from: "vanagonturbo"
Indeed. But there are similarities in terms of gearing, and what you hope to get out of the vehicle. Here's a link to another forum from someone with a similar question, and my response:
http://www.vwdieselparts.com/forum/viewtopic.php?t=8389
While I do not have a ton of experience swapping Vanagon/Transporter/Doka transmissions, I am familiar with the diesel gearing, and the 1.9TD swap (did it in my dad's Vanagon). I can't/won't tell you what to put in your car, but I will say that you might have to make a frankenstein trans to get what you want out of the car. Check the gear codes and play with the numbers, then decide what it best for you.
Not exactly. The ACH was the trans used in the diesel MKII. The ACN never came factory in any diesel
Reply #9June 24, 2008, 11:20:12 pm
myke_w
  • 1099
what would you do
« Reply #9 on: June 24, 2008, 11:20:12 pm »
aircooled vanagon is the tallest gearing out there, gotta use your bell housing of course,
Reply #10June 25, 2008, 01:10:55 am
monsho
  • 6
what would you do
« Reply #10 on: June 25, 2008, 01:10:55 am »
here you go:
http://www.brick-yard.co.uk/VehicleSpecific/T3/info/gbx.htm
this gives you all the ratio's for the different gearbox's.  On the vanagon, the NA diesel boxes are very very low geared.  Over here people generally try to find an AAP or AAR coded petrol box, off the 2.1.  These are the highest ratio boxes as standard and suits the AAZ pretty well.  Once tuned up, or especially a TDi conversion, you need to start looking at custom ratio's or final drives...
this is all for a 2WD though there are codes and ratio's for the syncro boxes there as well...
Reply #11June 25, 2008, 01:16:43 am
monsho
  • 6
what would you do
« Reply #11 on: June 25, 2008, 01:16:43 am »
oh yeah, and you need to take the bell housing off your diesel box as well as the input shaft (shorter on the diesel) for the swap over.
Aircooled box is pretty good, not quite as high geared as the AAP / AAR but its a very strong box, probably the strongest...
Reply #12June 25, 2008, 05:27:37 am
myke_w
  • 1099
what would you do
« Reply #12 on: June 25, 2008, 05:27:37 am »
I was thinking on our side of the drink :)
Reply #13June 25, 2008, 03:36:41 pm
monsho
  • 6
what would you do
« Reply #13 on: June 25, 2008, 03:36:41 pm »
did you guys get manual 2.1 wasserboxers, or were they mainly autos?
Reply #14June 25, 2008, 04:32:40 pm
myke_w
  • 1099
what would you do
« Reply #14 on: June 25, 2008, 04:32:40 pm »
both, but only 4 speed in manual
