Author Topic: what would you do  (Read 5572 times)
Reply #15June 26, 2008, 10:54:00 am
vanagonturbo
  • 639
    • Fine Tuning
what would you do
« Reply #15 on: June 26, 2008, 10:54:00 am »
My bad. These cars are getting so old and so many people have swapped transmissions that it can be hard to recollect what they came with every time ;)
Reply #16June 26, 2008, 03:46:20 pm
dokarex
  • 61
what would you do
« Reply #16 on: June 26, 2008, 03:46:20 pm »
Thanks for all the input.
Just to clear somethings up
It's an 87 that I imported from Germany
It came stock with the 1.6na diesel engine and tranny
The engine in it is a 1.9TD with 75,000KM
Now the big question where do I find the tranny code to compare numbers.  I was looking at the tables you sent me to and if it's the last Diesel tranny it has a 5.50 final would going to a 4.83 really make that much difference.
So far the 1.9TD has not been modified and would any of the mods on this site(Fuel screws)overcome any drawbacks to this switch.
Thanks
D
1987 1.9TD Doka from Germany gasser DU tranny, fuel turned up, 1.6 LDA pin, boost at 15 psi,egt and boost gauges,stock diesel tach,air filter behind passenger tail light, IC to come
2005 Jetta Wagen TDI
B6200 Kubota Diesel
16ft Freestyle catermeran
16ft Sunray 85HP
Reply #17June 26, 2008, 03:51:44 pm
VW_Commuter
  • 355
what would you do
« Reply #17 on: June 26, 2008, 03:51:44 pm »
It should be in the same place as others, on the bottom of the bell housing of the transaxle.
Greg
Greg
'06 Golf TDI traded in for a '12 Jeep Rubicon (the Phatbox is available)
'91 Jetta TD, a work in progress (I'll do a build thread when I start in earnest)
'65 Notchback, a project not yet started
Reply #18June 26, 2008, 04:56:06 pm
Possum79
  • 276
    • http://www.poscarclub.com
what would you do
« Reply #18 on: June 26, 2008, 04:56:06 pm »
http://www.brokevw.com/020oil.html
second picture has a spot highlighted to show where the code is. Also has other point like fill spot so you can figure out which way is which.
1979 VW Rabbit Diesel L
Reply #19June 26, 2008, 07:49:19 pm
vanagonturbo
  • 639
    • Fine Tuning
what would you do
« Reply #19 on: June 26, 2008, 07:49:19 pm »
That pic is for an 020 trans. Definitely not Vanagon/t3.
IIRC the code is on the drivers side directly below the reverse light switch housing.
Reply #20June 26, 2008, 09:03:55 pm
VW_Commuter
  • 355
what would you do
« Reply #20 on: June 26, 2008, 09:03:55 pm »
My bad, thought he was talking about his jetta.
Greg
Reply #21June 26, 2008, 11:10:51 pm
Possum79
  • 276
what would you do
« Reply #21 on: June 26, 2008, 11:10:51 pm »
definitely need to re pay attention. I read that before but totally forgot. My mistake.
Reply #22June 27, 2008, 01:11:13 am
monsho
  • 6
what would you do
« Reply #22 on: June 27, 2008, 01:11:13 am »
Quote from: "vanagonturbo"
Yep, what he said...
If it is the 5.50 final drive then pretty much any other box is going to make a big difference!
Reply #23June 27, 2008, 01:01:26 pm
dokarex
  • 61
what would you do
« Reply #23 on: June 27, 2008, 01:01:26 pm »
Actually looking at the chart again I think it's the 84.8 and up 1.6na 5.83 tranny; code ABF. I haven't been able to read the tranny code (needs cleaning) but it was a stock 87 1.6na and matching tranny.
What would then different final drive and gearing from a gas 87 vanagon do the top end currently 110KPM
1st gear 20KPH
2nd gear 40KPH
3rd gear 65KPH
B6200 Kubota Diesel
16ft Sunray 85HP
