what to use- oil feed and return
Topic: what to use- oil feed and return (Read 5866 times)
June 15, 2008, 11:03:34 am
vdubin_g60
June 15, 2008, 11:03:34 am »
I have a k14 that im going to put into a 1.6. Can;t find anything to use as far as oil feed and return lines. all i really want is some fitting and then i could use some high pressure rubber hoses.
what have you guys used?
June 16, 2008, 04:19:43 pm
vdubin_g60
June 16, 2008, 04:19:43 pm »
anyone know the size of the fitting or what the threads are.
June 16, 2008, 05:00:10 pm
Luckypabst
June 16, 2008, 05:00:10 pm »
M12 on top and M16 on the bottom. Verify before spending money.
Chris
'82 TD Westy
'81 NA Caddy
June 16, 2008, 05:11:28 pm
vdubin_g60
June 16, 2008, 05:11:28 pm »
know where to get them on the cheap?
June 16, 2008, 05:37:50 pm
June 16, 2008, 05:37:50 pm »
Having hoses that can withstand the heat are as important as pressure. Don't cheap out and get something like air hose, get something rated for hot oil.
June 16, 2008, 05:47:05 pm
vdubin_g60
June 16, 2008, 05:47:05 pm »
low price/cheap not cheap parts.
having a hard time finding the fittings/ hoses
about the only thing i can find
http://www.intengineering.com/Shop/Control/Product/fp/SFV/32093/vpid/4452259/vpcsid/0/rid/125251
June 16, 2008, 06:18:18 pm
Luckypabst
June 16, 2008, 06:18:18 pm »
Mine came from Pegasus racing - Metric (DIN) to AN adapters. The M16 adapter will protrude too far into the turbo cavity and needed to be shortened and re-chamfered.
Chris
'82 TD Westy
'81 NA Caddy
June 16, 2008, 06:38:13 pm
vdubin_g60
June 16, 2008, 06:38:13 pm »
anyone know tleast how many inches i need for a 1.6 motor.
48 inch Size 4 TFE Hose, Straight Swivel to 90 degree Swivel should be enough right?
June 17, 2008, 02:54:19 pm
vdubin_g60
June 17, 2008, 02:54:19 pm »
so is it a male m12 and then a female m16? thanks
June 17, 2008, 03:36:57 pm
Luckypabst
June 17, 2008, 03:36:57 pm »
Mine uses a male M16 fitting. But like I said, verify what you have first. I think there are at least two oil drain styles - one uses a single M16 threaded fitting, the other a two bolt flange.
Chris
Like this:
'82 TD Westy
'81 NA Caddy
June 17, 2008, 05:16:08 pm
vdubin_g60
June 17, 2008, 05:16:08 pm »
i'll get some pics tomarrow. the feed needs a male fitting and the return comes off a pipe and will need a female fitiing.
some reason i cant see the pic it just has a red x there. i think its on my side
Reply #11
June 17, 2008, 08:36:32 pm
Luckypabst
Reply #11 on:
June 17, 2008, 08:36:32 pm »
Does yours have a roughly 4" long straight pipe coming out the bottom of the turbo? That's what was on mine. Unscrew it from the turbo and you'll see where a male M16 fitting will screw in.
Chris
'82 TD Westy
'81 NA Caddy
Reply #12
June 17, 2008, 09:10:18 pm
vdubin_g60
Reply #12 on:
June 17, 2008, 09:10:18 pm »
ya same pipe. will 4 feet be enough for the feed and then 4 feet more for the return? or can i use less and how much less. thanks for all the help
Reply #13
June 17, 2008, 09:28:36 pm
Luckypabst
Reply #13 on:
June 17, 2008, 09:28:36 pm »
You'll have to measure on your own. I ended up using the existing feed line with the intent of upgrading to stainless AN hardline if I ever need some extra bling in the future.
The drain on mine is short but it's in a Van with the Quantum - down low - exhaust manifold. I'd guess that 2 feet of drain hose would be more than enough but a tape measure is your friend.
Chris
'82 TD Westy
'81 NA Caddy
Reply #14
June 19, 2008, 04:30:18 pm
vdubin_g60
Reply #14 on:
June 19, 2008, 04:30:18 pm »
only pic i can get at the moment you can see the pipe coming off the turbo
i think im just going to call pegasus when im ready and get the fittings and also steel lines.
thanks for the help
