Author Topic: what to use- oil feed and return  (Read 6169 times)
June 15, 2008, 11:03:34 am
vdubin_g60
  • 73
« on: June 15, 2008, 11:03:34 am »
I have a k14 that im going to put into a 1.6. Can;t find anything to use as far as oil feed and return lines. all i really want is some fitting and then i could use some high pressure rubber hoses.
what have you guys used?
Reply #1June 16, 2008, 04:19:43 pm
vdubin_g60
  • 73
« Reply #1 on: June 16, 2008, 04:19:43 pm »
anyone know the size of the fitting or what the threads are.
Reply #2June 16, 2008, 05:00:10 pm
Luckypabst
  • 502
« Reply #2 on: June 16, 2008, 05:00:10 pm »
M12 on top and M16 on the bottom. Verify before spending money.
Chris
'82 TD Westy
'81 NA Caddy
Reply #3June 16, 2008, 05:11:28 pm
vdubin_g60
  • 73
« Reply #3 on: June 16, 2008, 05:11:28 pm »
know where to get them on the cheap?
Reply #4June 16, 2008, 05:37:50 pm
« Reply #4 on: June 16, 2008, 05:37:50 pm »
Having hoses that can withstand the heat are as important as pressure. Don't cheap out and get something like air hose, get something rated for hot oil.
Reply #5June 16, 2008, 05:47:05 pm
vdubin_g60
  • 73
« Reply #5 on: June 16, 2008, 05:47:05 pm »
low price/cheap not cheap parts.
having a hard time finding the fittings/ hoses
about the only thing i can find
http://www.intengineering.com/Shop/Control/Product/fp/SFV/32093/vpid/4452259/vpcsid/0/rid/125251
Reply #6June 16, 2008, 06:18:18 pm
Luckypabst
  • 502
« Reply #6 on: June 16, 2008, 06:18:18 pm »
Mine came from Pegasus racing - Metric (DIN) to AN adapters. The M16 adapter will protrude too far into the turbo cavity and needed to be shortened and re-chamfered.
Chris
'82 TD Westy
'81 NA Caddy
Reply #7June 16, 2008, 06:38:13 pm
vdubin_g60
  • 73
« Reply #7 on: June 16, 2008, 06:38:13 pm »
anyone know  tleast how many inches i need for a 1.6 motor.
48 inch Size 4 TFE Hose, Straight Swivel to 90 degree Swivel  should be enough right?
Reply #8June 17, 2008, 02:54:19 pm
vdubin_g60
  • 73
« Reply #8 on: June 17, 2008, 02:54:19 pm »
so is it a male m12 and then a female m16?  thanks
Reply #9June 17, 2008, 03:36:57 pm
Luckypabst
  • 502
« Reply #9 on: June 17, 2008, 03:36:57 pm »
Mine uses a male M16 fitting. But like I said, verify what you have first. I think there are at least two oil drain styles - one uses a single M16 threaded fitting, the other a two bolt flange.
Chris
Like this:
'82 TD Westy
'81 NA Caddy
Reply #10June 17, 2008, 05:16:08 pm
vdubin_g60
  • 73
« Reply #10 on: June 17, 2008, 05:16:08 pm »
i'll get some pics tomarrow.   the feed needs a male fitting and the return comes off a pipe and will need a female fitiing.
some reason i cant see  the pic it just has a red x there. i think its on my side
Reply #11June 17, 2008, 08:36:32 pm
Luckypabst
  • 502
« Reply #11 on: June 17, 2008, 08:36:32 pm »
Does yours have a roughly 4" long straight pipe coming out the bottom of the turbo? That's what was on mine. Unscrew it from the turbo and you'll see where a male M16 fitting will screw in.
Chris
'82 TD Westy
'81 NA Caddy
Reply #12June 17, 2008, 09:10:18 pm
vdubin_g60
  • 73
« Reply #12 on: June 17, 2008, 09:10:18 pm »
ya same pipe.  will 4 feet be enough for the feed and then 4 feet more for the return? or can i use less and how much less. thanks for all the help
Reply #13June 17, 2008, 09:28:36 pm
Luckypabst
  • 502
« Reply #13 on: June 17, 2008, 09:28:36 pm »
You'll have to measure on your own. I ended up using the existing feed line with the intent of upgrading to stainless AN hardline if I ever need some extra bling in the future.
The drain on mine is short but it's in a Van with the Quantum - down low - exhaust manifold. I'd guess that 2 feet of drain hose would be more than enough but a tape measure is your friend.
Chris
'82 TD Westy
'81 NA Caddy
Reply #14June 19, 2008, 04:30:18 pm
vdubin_g60
  • 73
« Reply #14 on: June 19, 2008, 04:30:18 pm »
only pic i can get at the moment    you can see the pipe coming off the turbo
i think im just going to call pegasus when im ready and get the fittings and also  steel lines.
thanks for the help
