General Information
Troubleshooting
how much slop
Topic: how much slop (Read 4205 times)
May 23, 2008, 06:47:01 am
TOW'D
how much slop
May 23, 2008, 06:47:01 am »
Hey gang,
I've got the right front axle out of our '85 Golf .
The tire is still on and I found a lot of slop in what seems to be the front wheel bearing, or does it all tighten up when the axle is back on and torqued up?
I didn't notice any slop when it was all back together and I was pulling the studded tires off and installing the summer tires.
thanks
hank
way too many projects not much time
May 23, 2008, 01:36:34 pm
how much slop
May 23, 2008, 01:36:34 pm »
it should tighten up as the nut is tightened. That's why a car without the axles installed won't roll. The bearing is supported by the axle shaft causing the bearings to line up in their races.
May 24, 2008, 07:49:43 am
TOW'D
how much slop
May 24, 2008, 07:49:43 am »
caveman thanks
that was just what I wanted to hear
the more I work on these cars the more I like them
great learning process
hank
May 24, 2008, 08:09:20 pm
Quantum TD
how much slop
May 24, 2008, 08:09:20 pm »
When new, the bearings should have no slop. But with 40k+ on them, expect some in and out. Nothing to worry about as Caveman notes. If you hear noises, that's your first sign.
May 25, 2008, 06:51:19 am
how much slop
May 25, 2008, 06:51:19 am »
Don't roll the car around with no axles. You will ruin the bearings, sometimes within 10 feet.
May 25, 2008, 07:24:05 am
TOW'D
how much slop
May 25, 2008, 07:24:05 am »
I'm going to keep the old outer CV to install in case I need to move a Golf with the engine and transaxle removed
thanks for the tip
hank
General Information
Troubleshooting
how much slop
