Author Topic: how much slop  (Read 4214 times)
May 23, 2008, 06:47:01 am
TOW'D
  • 100
how much slop
« on: May 23, 2008, 06:47:01 am »
Hey gang,
 I've got the right front axle out of our '85 Golf .
The tire is still on and I found a lot of slop in what seems to be the front wheel bearing, or does it all tighten up when the axle is back on and torqued up?
I didn't notice any slop when it was all back together and I was pulling the studded tires off and installing the summer tires.
thanks
hank
way too many projects not much time
Reply #1May 23, 2008, 01:36:34 pm
  • 1739
how much slop
« Reply #1 on: May 23, 2008, 01:36:34 pm »
it should tighten up as the nut is tightened. That's why a car without the axles installed won't roll. The bearing is supported by the axle shaft causing the bearings to line up in their races.
Reply #2May 24, 2008, 07:49:43 am
TOW'D
  • 100
how much slop
« Reply #2 on: May 24, 2008, 07:49:43 am »
caveman thanks
that was just what I wanted to hear
the more I work on these cars the more I like them
great learning process
hank
Reply #3May 24, 2008, 08:09:20 pm
Quantum TD
  • 1195
how much slop
« Reply #3 on: May 24, 2008, 08:09:20 pm »
When new, the bearings should have no slop. But with 40k+ on them, expect some in and out. Nothing to worry about as Caveman notes. If you hear noises, that's your first sign.
Reply #4May 25, 2008, 06:51:19 am
how much slop
« Reply #4 on: May 25, 2008, 06:51:19 am »
Don't roll the car around with no axles. You will ruin the bearings, sometimes within 10 feet.
Reply #5May 25, 2008, 07:24:05 am
TOW'D
  • 100
how much slop
« Reply #5 on: May 25, 2008, 07:24:05 am »
I'm going to keep the old outer CV to install in case I need to move a Golf with the engine and transaxle removed
thanks for the tip
hank
