Author Topic: PD150/130 GP Voltage  (Read 3179 times)
May 19, 2008, 05:20:37 pm
lbreton
  • 56
« on: May 19, 2008, 05:20:37 pm »
Does anybody know if the '00 PD150/130 (ARL/ASZ) used a 12V Glow plug system, or did they switch to the ceramic tip 7V GP ahead of North America (NA)?  I have been looking at my wire diagram and it looks like a simple 12V system. In NA, all the PD's run ceramic tip.  I was looking at the ceramic tips a a VW dealer and they are longer than the 12V style.
thanks guys
'97 F250 5.9 Cummins, POD's, PDR cam, Custom Pump, Stage II Port, 14CM, blabla
'92 Passat Syncro- AHU eTDI, PP520's, 2.5 Str
'99 Audi A4 Quattro - 2.0 BHW TDI, EDC15P, GT2056V, AWIC, 5Speed Euro Tranny - 214Whp/363TQ
Reply #1May 19, 2008, 07:54:10 pm
Tintin
  • 1279
« Reply #1 on: May 19, 2008, 07:54:10 pm »
It's 12 Volt.
Reply #2May 19, 2008, 08:57:39 pm
lbreton
  • 56
« Reply #2 on: May 19, 2008, 08:57:39 pm »
Quote from: "Tintin"
It's 12 Volt.
thanks TinTin,
I think what I am doing is similar to yours.  I have the ARL 40 pin engine harness, and I have an ALH 80 pin harness for the other plug.
Will the ALH glow plug relay work with the ARL (EDC15P) ECU, or will it CEL?
Also, I am using this on a BHW engine, which has 7V GP's.  I like the idea of using the 12V GP, instead of the fragile ceramics.  Can you see any issues with 12V's fitting this PD head and functioning properly? I have noted that the 7V's are about 1/2" longer than the 12V's.  Is your PD using standard ALH GP's or something else?
Reply #3May 20, 2008, 08:27:17 pm
Tintin
  • 1279
« Reply #3 on: May 20, 2008, 08:27:17 pm »
I never compare my 150 glow plug with ALH one, but they are definately no ceramic.
I do not remember exactly, but the ALH glow plug system is the same as ARL, all EDC15 in fact.
My engine is year 2003.
Reply #4May 20, 2008, 09:43:13 pm
lbreton
  • 56
« Reply #4 on: May 20, 2008, 09:43:13 pm »
thanks TinTin, I just got a comparison from VWMikel and the ALH and the ARL GP's are the exact same unit.  I'll get a new relay on my harness and go with it.  I guess the length difference does not make a difference becuase of the angle it enters the combustion chamber.  I'll be glad to toss the ceramic GP's.   8)
