Author Topic: cruise cuts out  (Read 3929 times)
April 24, 2008, 06:26:38 pm
600K
cruise cuts out
« on: April 24, 2008, 06:26:38 pm »
the cruise control on my 94 cuts out erratically,  sometimes will reset, sometimes not.  I have tested the vacuum and circuits as per the bently manual, all checks out well.  any ideas?
Reply #1April 24, 2008, 09:21:48 pm
cruise cuts out
« Reply #1 on: April 24, 2008, 09:21:48 pm »
Replace the control box if everything else checks out good.
Reply #2April 25, 2008, 07:44:43 am
  • 1739
cruise cuts out
« Reply #2 on: April 25, 2008, 07:44:43 am »
Alot of the times either the brake or clutch switch gets out of adjustment and becomes too " sensitive". If you have a meter connect at either one, and it should take at least i inch of pressing at the pedal for the signal to get cut. The stalk with the on/off switch after some time wear also.
Reply #3April 25, 2008, 08:02:51 am
ricosuave
  • 244
cruise cuts out
« Reply #3 on: April 25, 2008, 08:02:51 am »
go through the diagnostic procedure in the bentley manual
the lines are on a vacuum system, sometimes they need to be changed too
do a search on vwvortex.com forums, there is a how to there
Now: 00 2dr Golf TDI, 03 Jetta Wagon TDI, 02 2500HD Duramax - :)
Then: 69 SC Transporter, 84 Rabbit GTI, 87 Fox GL, 91 Golf IDI, 96 Passat Wagon TDI, 97 Jetta IDI - :(
"Everything I save by driving diesel I put back due to poor German engineering and crappy Mexican workmanship!"   :P
