General Information
Troubleshooting
cruise cuts out
Topic: cruise cuts out (Read 3931 times)
April 24, 2008, 06:26:38 pm
600K
cruise cuts out
April 24, 2008, 06:26:38 pm »
the cruise control on my 94 cuts out erratically, sometimes will reset, sometimes not. I have tested the vacuum and circuits as per the bently manual, all checks out well. any ideas?
April 24, 2008, 09:21:48 pm
cruise cuts out
April 24, 2008, 09:21:48 pm »
Replace the control box if everything else checks out good.
April 25, 2008, 07:44:43 am
cruise cuts out
April 25, 2008, 07:44:43 am »
Alot of the times either the brake or clutch switch gets out of adjustment and becomes too " sensitive". If you have a meter connect at either one, and it should take at least i inch of pressing at the pedal for the signal to get cut. The stalk with the on/off switch after some time wear also.
April 25, 2008, 08:02:51 am
ricosuave
cruise cuts out
April 25, 2008, 08:02:51 am »
go through the diagnostic procedure in the bentley manual
the lines are on a vacuum system, sometimes they need to be changed too
do a search on vwvortex.com forums, there is a how to there
Now: 00 2dr Golf TDI, 03 Jetta Wagon TDI, 02 2500HD Duramax -
Then: 69 SC Transporter, 84 Rabbit GTI, 87 Fox GL, 91 Golf IDI, 96 Passat Wagon TDI, 97 Jetta IDI -
"Everything I save by driving diesel I put back due to poor German engineering and crappy Mexican workmanship!"
General Information
Troubleshooting
cruise cuts out
