Weird Pistons!!
Topic: Weird Pistons!! (Read 6381 times)
April 01, 2008, 12:49:05 pm
Torchd
Weird Pistons!!
April 01, 2008, 12:49:05 pm »
I found these pistons in scrap... the have a 79.48mm(1.9 diesel) diameter... but the connecting rod length/wrist pin diameter of a 1.6 diesel..
They have audi and KS logo on them, and they also have the turbo oil squirter cut in them. i was wondering which engine they are from and if i can use them in a 1.6TD?
April 01, 2008, 12:50:13 pm
Weird Pistons!!
April 01, 2008, 12:50:13 pm »
Perhaps the 1.7l engine?
April 01, 2008, 01:03:26 pm
Weird Pistons!!
April 01, 2008, 01:03:26 pm »
yes i also believe they came out of a 1.7L . It's the same bore as a 1.9 but with a 1.6 L stroke.
April 01, 2008, 01:04:14 pm
Torchd
Weird Pistons!!
April 01, 2008, 01:04:14 pm »
Which engine is thatt?? :roll:
Can i use them in my 1.6?? if i bore it to that diameter??
April 01, 2008, 01:12:57 pm
mdonau
Weird Pistons!!
April 01, 2008, 01:12:57 pm »
its from T3 (vanagon, transporter) 1,7L Motorcode: KY
Audi 80 1,6TD:
http://rapsdb.rapsinfo.de/detail.php?id=1807
1,9l TD conversion done!
April 01, 2008, 01:16:00 pm
Torchd
Weird Pistons!!
April 01, 2008, 01:16:00 pm »
KY... is that a TURBO DIESEL??
April 01, 2008, 01:25:31 pm
Torchd
Weird Pistons!!
April 01, 2008, 01:25:31 pm »
If i post the part number... will some one be able to run it for me ??
April 01, 2008, 01:33:00 pm
myke_w
Weird Pistons!!
April 01, 2008, 01:33:00 pm »
i can run it
April 01, 2008, 01:34:10 pm
myke_w
Weird Pistons!!
April 01, 2008, 01:34:10 pm »
the 1.7's were not td's IIRC, they were bus motors so they added the squirters and drilled the heads and blocks for better water flow
April 01, 2008, 01:39:48 pm
Torchd
Weird Pistons!!
April 01, 2008, 01:39:48 pm »
cool! i will post the part number tomorrow.... were those motors diesels tho?
April 01, 2008, 01:47:49 pm
myke_w
Weird Pistons!!
April 01, 2008, 01:47:49 pm »
yes, came in transporters in Europe, maybe other places
Reply #11
April 01, 2008, 01:50:28 pm
Weird Pistons!!
Reply #11 on:
April 01, 2008, 01:50:28 pm »
could also belong to the na version of the aaz
Reply #12
April 01, 2008, 02:06:55 pm
Torchd
Weird Pistons!!
Reply #12 on:
April 01, 2008, 02:06:55 pm »
Was that a diesel engine? and which year was it?
so can these pistons in my 1.6 td??
Thanx!
Reply #13
April 01, 2008, 02:09:10 pm
Weird Pistons!!
Reply #13 on:
April 01, 2008, 02:09:10 pm »
It has been discussed that you won't have much metal left if you bore it out to that size, but no one has tried it as far as I know.
Reply #14
April 01, 2008, 02:41:40 pm
Torchd
Weird Pistons!!
Reply #14 on:
April 01, 2008, 02:41:40 pm »
Jim... my 1.6 block already has KS cylinder liners in it and i've been using the car for the past 5 years now which means the bore size has already increased... so what if i take the liner out and use KY pistons?
Weird Pistons!!
