Author Topic: Weird Pistons!!  (Read 6357 times)
Reply #15April 01, 2008, 03:11:29 pm
Weird Pistons!!
« Reply #15 on: April 01, 2008, 03:11:29 pm »
Who knows? Then I guess you'd be the first to see if it will work or not.
Reply #16April 01, 2008, 11:27:06 pm
mdonau
  • 53
Weird Pistons!!
« Reply #16 on: April 01, 2008, 11:27:06 pm »
Quote from: "jimfoo"
it works, just make the Bore to 79,51..clearance is at 0,03mm for IDI
i know one 1,6TD Engine (driven very hard) made 60.000km until one cylinder-wall cracked.
on the next completely new engine engine a  conrod cracked after 1500km
if it is a hydraulic lifter block i suggest a 1,9 with metal-headgasket would be good for performance, the extra coolant holes can be drilled in the 1,6 block.
Audi 80 1,6TD:
http://rapsdb.rapsinfo.de/detail.php?id=1807
1,9l TD conversion done!
Reply #17April 01, 2008, 11:48:24 pm
Torchd
  • 372
Weird Pistons!!
« Reply #17 on: April 01, 2008, 11:48:24 pm »
The engine with the cracked wall and cracked conrod was a 1.6 block bored to take 1.7 pistons??
yea my 1.6 block is hydraulic lifter one...  so u mean i shoud use head from a 1.9 with metal headgasket?
Quote from: "mdonau"
Reply #18April 02, 2008, 02:09:19 am
mdonau
  • 53
Weird Pistons!!
« Reply #18 on: April 02, 2008, 02:09:19 am »
Quote from: "Torchd"
yes it was a 1,6TD with 1,7l pistons
if you want Performance running high boost at high RPM, it may be a good way to go.
Audi 80 1,6TD:
Reply #19April 02, 2008, 02:30:32 am
Torchd
  • 372
Weird Pistons!!
« Reply #19 on: April 02, 2008, 02:30:32 am »
Hmm yeha thats what i think.. But then i want reliability and mid range torque as well..
Which setup out of the two will give me a fast, reliable, torquey performance car. My car is an MKII.
Setup1
1.6 (MF)Turbo (I dont know the turbo name; please tell me if you do. Its a KKK tho)
1.6 Turbo IP with GTD Nozzles.
1.9 stock head
1.9 Stock Block.
Setup2
1.6 (MF) Turbo
1.6 Turbo IP with GTD nozzles.
1.9 Stock Head
1.6 Block with 1.7 pistons.
Reply #20April 02, 2008, 02:35:31 am
Torchd
  • 372
Weird Pistons!!
« Reply #20 on: April 02, 2008, 02:35:31 am »
The part number is 079 106
Then theres a + sign and 24.
On the opposite its written 49.5... (i dont know what this is and that +24 means)
Quote from: "myke_w"
i can run it
Reply #21April 02, 2008, 06:58:27 am
Weird Pistons!!
« Reply #21 on: April 02, 2008, 06:58:27 am »
Setup1
1.9 stock head
1.9 Stock Block.
Setup2
1.6 (MF) Turbo
1.9 Stock Head
From the post above, the #2 setup doesn't sound very reliable. The block probably cracked from too little metal being left after the over bore. 1.9 will give more torque and be way more reliable in my opinion.
Reply #22April 02, 2008, 11:17:39 pm
Torchd
  • 372
Weird Pistons!!
« Reply #22 on: April 02, 2008, 11:17:39 pm »
Thanx jimfoo!
With setup one, what kinda power should i be looking at? and would you know the type of the turbo i have... (MF)
Reply #23April 03, 2008, 10:57:55 pm
Torchd
  • 372
Weird Pistons!!
« Reply #23 on: April 03, 2008, 10:57:55 pm »
This is whats written on the compressor side of my MFengine turbo.
36W
KKK (in a triangle format)
5342 101 50  (99 is written in a circle it might be the serial number or sumthing)
So what turbo do i have?
Reply #24April 03, 2008, 11:15:54 pm
myke_w
  • 1099
Weird Pistons!!
« Reply #24 on: April 03, 2008, 11:15:54 pm »
the 1.7 motor is coded KY
the full piston # is 033 107 065
If you have an mf, and you have a 3k turbo, it's likely a k24. Is there a 068 # on the tag?
Reply #25April 05, 2008, 07:57:20 pm
Zulfiqar
  • 254
Weird Pistons!!
« Reply #25 on: April 05, 2008, 07:57:20 pm »
you should find a blue metal tag on the inside of the compressor side - it should say the model number on it..
the 99 thing in the circle is the manufacturing date you should also see dots in it a max of 12 - then the year number changes.
Diesel IS the future
Reply #26April 06, 2008, 11:54:13 pm
Torchd
  • 372
Weird Pistons!!
« Reply #26 on: April 06, 2008, 11:54:13 pm »
Thanx Zulfiqar..
U didnt reply to my messge..?
Which Turbo did u have on ur golf in pk??  and i dont think the number in the circle is the manufacturing date.. cuz my Merc e300td...  has the number 74 in the circle... and the car is a 99 year..  so thats contradicting!
