Author Topic: IDI to TDI  (Read 75517 times)
Reply #135March 15, 2008, 08:31:10 pm
IDI to TDI
« Reply #135 on: March 15, 2008, 08:31:10 pm »
Well, I'm hoping to be on the road tomorrow, barring more problems. Today I had to fix a leaking water neck on the head, which was a big pain with injector lines, wires, hoses and linkages in the way. I just threw some Right Stuff on it since I didn't have another o-ring. This time I pressure tested it with air before filling it. Got the exhaust wrapped with header wrap, battery box in, alternator in, idler pulley for the water pump on, turbo heat shield modified and put on. I also bought a new Optima so I don't have to worry about acid eating my air hose again. I found the cable for the VNT was very frayed, so I got a new cable for it.
I still need to make sure the fan works, hook up all the turbo tubing to the IC, air filter, manifold ant turbo. The timing sounds a little too advanced, especially with power to the timing solenoid, so I will have to adjust it a little. I need to redo the air filter mount, put on all the body panels I took off. Then I just need to replace my clutch master and I think I am ready to roll!!! :twisted:  :twisted:  :twisted:  :twisted:
Reply #136March 17, 2008, 07:25:34 pm
IDI to TDI
« Reply #136 on: March 17, 2008, 07:25:34 pm »
I took my first short test drive this evening!!! The timing still sounds a bit too advanced, so I will retard it a bit more tomorrow. Other than that, it seemed ok for an eco-TDI. I'm thinking the boost line came off the boost gauge as it doesn't move at all, so the LDA probably wasn't adding any extra fuel. The bad thing is my clutch was slipping a bit when I gave it a good amount of throttle. It has done that in the past from a time or two it got some oil on it, so hopefully it will just burn off or something. If not, I guess I can get a puck type clutch disc for a BMW as it will fit with a little filing of the splines. I probably better put my front axle in as well as I got stuck in the snow in my driveway. :lol: It was hard to tell from such a short drive, but it did seem like it had more torque.
Reply #137March 18, 2008, 05:37:36 am
Vanagoner
  • 219
IDI to TDI
« Reply #137 on: March 18, 2008, 05:37:36 am »
Fantastic work!  I'm impressed.
I'd like to come down and see it when I have some time.
Sage
'82  Vanagon Westy, the mighty N/A
Reply #138March 18, 2008, 06:24:20 am
IDI to TDI
« Reply #138 on: March 18, 2008, 06:24:20 am »
I could drive up there sometime. You KNOW I want to start driving it once all the little bugs are worked out. :lol:
Reply #139March 18, 2008, 08:35:08 am
IDI to TDI
« Reply #139 on: March 18, 2008, 08:35:08 am »
video?  :D
Reply #140March 18, 2008, 08:49:15 am
IDI to TDI
« Reply #140 on: March 18, 2008, 08:49:15 am »
I'll work on it. What do you want it to be of?
Reply #141March 18, 2008, 08:58:45 am
IDI to TDI
« Reply #141 on: March 18, 2008, 08:58:45 am »
startup, take off and a good beating please
Reply #142March 18, 2008, 09:04:42 am
IDI to TDI
« Reply #142 on: March 18, 2008, 09:04:42 am »
Will do! :lol:  I need to fix my minor problems first, so it probably won't be until later. Also don't forget that my pump setup isn't supposed to be that great as I haven't modified the control lever yet.
Reply #143March 18, 2008, 12:52:48 pm
Vanagoner
  • 219
IDI to TDI
« Reply #143 on: March 18, 2008, 12:52:48 pm »
"I could drive up there sometime. You KNOW I want to start driving it once all the little bugs are worked out. "
...there is always lefthand canyon... :twisted:
Sage
Reply #144March 18, 2008, 06:40:20 pm
IDI to TDI
« Reply #144 on: March 18, 2008, 06:40:20 pm »
Here it is, though I'm not totally thrashing it. Too many dogs, kids , cars on my road to fly down it. For some reason, the idle speed is up quite a bit. I'm wondering if I hit the cold start as it has no cable on it and I put something back there to pry the pump out a little to change the timing. I should get one from outside to see what the smoke is like. I know there is a bit when shifting though.
Reply #145March 18, 2008, 08:23:45 pm
boxer246
  • 109
nice work
« Reply #145 on: March 18, 2008, 08:23:45 pm »
Awesome Jim.....thats too cool!
Ash
'81 VW Caddy 1.6 now a TD
'88 Vanagon (building a AHU M-TDI)
Reply #146March 18, 2008, 09:28:47 pm
IDI to TDI
« Reply #146 on: March 18, 2008, 09:28:47 pm »
wow that things fast. 0-60 before you even started it :shock:  :lol:
I'm highly impressed
Reply #147March 18, 2008, 09:31:55 pm
IDI to TDI
« Reply #147 on: March 18, 2008, 09:31:55 pm »
:lol:  :lol:  :lol:  You noticed. Yeah, I screwed it up when I was cleaning a bunch of crap out of it. At least the odometer works now though. Clutch is still slipping, but seems better
Reply #148March 19, 2008, 03:23:21 pm
IDI to TDI
« Reply #148 on: March 19, 2008, 03:23:21 pm »
Did my first significant test drive today, about 65 miles of very mixed driving. About 20 of 30 mph road, 25 of stop and go city driving, and about 20 highway, mostly uphill with a head wind. Average of 27.5 mpg. That's close to the best(30) just highway mileage I ever got with a broken in engine. Also I don't think my fan ever came on as the temp never got high enough, which was the biggest problem with my old AAZ. EGT's did get to around 1300, which may be due to timing or the fact that for some reason my boost doesn't get as high. Maybe being more efficient, a TDI puts out less exhaust gas? I know the turbo can make it as the actuator got off center a little and boost got way higher, but the setup was the same I had on the AAZ. It made 18 where I had it set on the AAZ and only 10 on the TDI. I did put another spring in the actuator before the drive, which brought it up to 15 psi. Power seems decent, at least what the AAZ had from what I can tell with the slipping clutch.
Reply #149March 19, 2008, 03:54:24 pm
rallydiesel
  • 1880
IDI to TDI
« Reply #149 on: March 19, 2008, 03:54:24 pm »
Cool. So did you have to time the IP differently than the IDI?
Will this be an easy job for Giles (I think you said you were sending your pump to Giles?) to set-up? I am just wondering if this engine would just be treated like any 1Z. etc m-TDI or if he needs to have the engine for tuning? Does Giles even do m-TDI pumps?
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
