T3 2.5" DP boxlesss side exit system GTD - pics/vids/ad
Topic: T3 2.5" DP boxlesss side exit system GTD - pics/vids/ad (Read 15913 times)
September 12, 2007, 07:08:02 am
Stanton
Newbie
September 12, 2007, 07:08:02 am »
hi there,
im trying to setup my autometer tach, and cannot use the idle as a basline as this is not standard.
i need to know what the engine will rev out to to set the redline. i have not done the governer mod.
is the figure 4500 or 4800? or something else.
any help would be greatly appreciated... esp from those with GTD's with o.e tachos
September 12, 2007, 08:33:12 am
Stanton
Newbie
September 12, 2007, 08:33:12 am »
hi,
this is great info. ill seek out a shop with the tools - but for now if i could know the approx redline that would be great
im in the uk btw
this is the car in question
September 12, 2007, 08:51:13 am
Audi80
September 12, 2007, 08:51:13 am »
So you´re at dyno, what´s the results
September 12, 2007, 10:14:27 am
gnavs
September 12, 2007, 10:14:27 am »
Huge lips. I love it
September 12, 2007, 02:42:34 pm
September 12, 2007, 02:42:34 pm »
the best way to set your tach accurately is make sure your speedometer is accurate using one the radar trailer things the cops let sit along the road, then once u know ur speedo is close to what it should be find the gearing of your transmission and figure out what speed your engine will be at at 60 mph in 5th gear, or w/e and check a couple different speeds in different gears and what not.
September 12, 2007, 03:13:27 pm
numbnuts
September 12, 2007, 03:13:27 pm »
Hi Mate, the red line on my tacho is about 4750. GTD that is.
Just sent u over here from e38, and then read this so u have already found it, ah well. :roll:
Was that your caddy that was on stage at e38? These guys need a pic of that beauty :oops:
September 12, 2007, 05:58:42 pm
zagarus
September 12, 2007, 05:58:42 pm »
^ yes, yes we do.
And that is one hot GTD!!
Project 1.9TD Jetta Coupe Completed. Back in action!
September 13, 2007, 01:40:52 am
Stanton
Newbie
September 13, 2007, 01:40:52 am »
haha thanks guys!
not my caddy - a good mate of mines tho, AAZ with T3, pump mods and 2.5" exhaust with no mufflers - just a pipe, runs 28psi of boost :lol:
mines a GTD with a T2 and downpipe back 2.25 system (still got the ***ty o.e dp) running 20psi and some pump mods to suit... oh and an AAZ gasket.
only hit 88bhp and 158ft/lb on the dyno. we couldnt get the transmisson loss calculated properly cause we didnt know the RPM at 60!
it should be over 100bhp really i would have thought.
i fractured an injector rail last night so im going for a T3 with a custom 2.25" downpipe going straight to the floor... no side exit were talkin under the car exit
with some head studs and more tuning.
another question - you rekon its worth my while to go to AAZ injectors?
how much boost do you think my setup will take safely and what power should i hit?
thanks guys
ill get you some pics of the caddy from hell :wink:
September 13, 2007, 01:47:49 am
Stanton
Newbie
September 13, 2007, 01:47:49 am »
rich's car started out as...
then went sour!!!
p.s does anyone know what EGT i should be hitting with a T3 and free flowing downpipe?
September 13, 2007, 02:31:33 pm
con
September 13, 2007, 02:31:33 pm »
Hey mate, your GTD looks brilliant, any chance of some more pictures?!
September 13, 2007, 06:46:46 pm
subsonic
September 13, 2007, 06:46:46 pm »
Quote from: "Stanton"
Subsonic wrote:
"Also am holding in my hands a new set of nozzles for my 1.9td injector bodies. I decided to go with the DN0 SD 265 ( 0 434 250 128 ). These are the newest updates for the Mercedes 300TD. I will be having these done up this week."
These will fit in the 1.6 bodies as well.
This has a lot of info on this subject
http://vwdiesel.net/phpBB/viewtopic.php?t=6947&start=0&postdays=0&postorder=asc&highlight=mercedes
Reply #11
September 15, 2007, 01:40:59 pm
Hillshy
Reply #11 on:
September 15, 2007, 01:40:59 pm »
this can really depend in fuel settings, over fueling can help lower egt, less fuel can really heat things up again.
i'm running a Sb 1.6 td, kkk14 20psi boost aaz metal gasket, ext oil cooler my egt temp really differ when i play with fuel delivery side of things. i tink im around 100 horses too.
nice cars there BTW, im also a uk'r, pleased to meet you. what area you in?
ps mines T3 caravelle :wink:
where was the last photo taken? which show?
Hillshy T25 caravelle "Hilli" currently thrashing 1.6 td GTD engine
NOT SO FRIGGEN HILLSHY ANYMORE!
15psi of BOOST set my c'velle free
Reply #12
September 16, 2007, 01:41:32 am
Tiz
User+
Reply #12 on:
September 16, 2007, 01:41:32 am »
pretty sure EGT increases with more fuel. More smoke = higher EGT. Less fuel means the burn will be completed fully and there will be no smoke and much lower EGT
i <3 diesel
Reply #13
September 16, 2007, 12:17:48 pm
Mark(The Miser)UK
Reply #13 on:
September 16, 2007, 12:17:48 pm »
To find rpm @60; jack up front wheel stick in 5th an rotate for 1 rev of engine find out circumference of wheel find out revs per mile...
Mark-The-Miser-UK
Reply #14
September 16, 2007, 12:34:49 pm
Stanton
Newbie
Reply #14 on:
September 16, 2007, 12:34:49 pm »
hi guys, thanks for the replys!
im from southampton, not too far from london!!! the pics from the ed38 show 1st sept in northampton
little more progress....
defo liking what i read on that nozzle link - thanks for that
T3 on...
manifold wrapped
DP cobbled together out of old bends lying about
just looking for a replacement metal injection pipe... cant get one anywhere.... reli struggling right now. anyone know the vw part nos?
oh and some more pics of the car
thanks again for the help guys :wink:
