Author Topic: Cheaper EGT options?  (Read 7251 times)
August 21, 2007, 10:01:36 am
numbnuts
  • 99
« on: August 21, 2007, 10:01:36 am »
Hi, I have been pricing up the EGT's as i want to turn up the boost on my 91 GTD. They seem so expensive, are there any cheap ones out there? And from reading the guides on here, i am right in thinking i need one before i turn up the boost aren't i? :?
Cheers Joel
Reply #1August 21, 2007, 10:15:58 am
Slave2School
  • 531
« Reply #1 on: August 21, 2007, 10:15:58 am »
"Westach" makes an inexpensive somewhat ugly non powered aircraft gauge you might want to investigate.  ~$80CDN with the probe.
2002 ford focme wagon
Reply #2August 21, 2007, 11:59:50 am
myke_w
  • 1099
« Reply #2 on: August 21, 2007, 11:59:50 am »
Reply #3August 21, 2007, 12:44:02 pm
vwmike
  • 1158
« Reply #3 on: August 21, 2007, 12:44:02 pm »
Watch out for some of the cheaper gauges on the market. Generally speaking, some of the cheaper gauges are also slower reacting. I had a VDO in the past and I thought it was garbage. I have an Autometer now and it is a lot faster though I wish it could be even faster.
Reply #4August 21, 2007, 12:51:03 pm
Slave2School
  • 531
« Reply #4 on: August 21, 2007, 12:51:03 pm »
The westach was super fast, at least as fast as the electronic Tdi gauge I have, that is why I recommend it, very good for the $$$ and I believe westach would be more easily accessible in the UK.  (common for home builder aircraft kits to use such gauges so any aircraft places near you should have them).
Reply #5August 21, 2007, 02:37:27 pm
foxracer1
  • 991
« Reply #5 on: August 21, 2007, 02:37:27 pm »
If your using the gauge to protect your engine you should buy a quality one. That would be like wering a cheap ass helmet from wal-mart.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #6August 21, 2007, 02:45:01 pm
Slave2School
  • 531
« Reply #6 on: August 21, 2007, 02:45:01 pm »
The westach stuff is good, made for aircraft :)  Just not pretty.
Reply #7August 21, 2007, 03:49:53 pm
Black Smokin' Diesel
  • 656
« Reply #7 on: August 21, 2007, 03:49:53 pm »
Reply #8August 21, 2007, 05:21:51 pm
foxracer1
  • 991
« Reply #8 on: August 21, 2007, 05:21:51 pm »
I paid $120 for my Autometer and it came with a weld in bung, pipe thread bung and a hose clamp set up that just requires a hole drilled. Plus of coruse the probe and lead. Fonud it brand new on ebay.
91 S10 305 TPI T56
Reply #9August 21, 2007, 05:27:15 pm
Slave2School
  • 531
« Reply #9 on: August 21, 2007, 05:27:15 pm »
My current tdi setup was ~160 shipped to my door :)  It is a 2 in 1 analog boost and digital egt that scales the digits.
poor quality camera phone http://www.youtube.com/watch?v=FHYxfJLCszc
View more pics at tdiclub.com search "tdi boost gauge"
Reply #10August 22, 2007, 03:23:18 am
Slave2School
  • 531
« Reply #10 on: August 22, 2007, 03:23:18 am »
I agree, it worked really well, it just didn't fit the MK IV decor.  I am still using the westach probe with the new gauge since it did work so well.  for the money hard to beat.
Reply #11August 22, 2007, 07:06:13 am
« Reply #11 on: August 22, 2007, 07:06:13 am »
I bought a fairly inexpensive one before I really read this forum much, but it seems to work ok and has what I think is a decent response, but I haven't ever seen another to compare it to so I don't know for sure. I'm sure it isn't the same quality as the better gauges, but as long as it keeps me from cooking my engine, that's what counts. http://www.glowshiftdirect.com/index.asp?PageAction=VIEWPROD&ProdID=192
$89 including the probe and 6' of wire. The only bad thing is the tinted one was almost impossible to read in the daytime due to me having such an open vehicle that lets in a lot of light. Probably would have been fine with tinted windows. I ended up making my own clear bezel.
Reply #12August 22, 2007, 07:28:39 am
« Reply #12 on: August 22, 2007, 07:28:39 am »
Quote from: "Slave2School"
That's really cool, but I cannot find that setup on TDIClub.  Searching "TDI boost gauge" nets me 1317 hits.  If I narrow it down with your username I still get 313 hits (in 47.9 seconds) and I picked through about half of those and still cant find it!  Can you point me a little closer?  Where did you get it from?
Thanks,
Reply #13August 22, 2007, 07:47:46 am
Slave2School
  • 531
« Reply #13 on: August 22, 2007, 07:47:46 am »
Here is the thread that started it all...very long, some prototype pics at teh begining, but new finished units at the end.
http://forums.tdiclub.com/showthread.php?t=155230&highlight=tdi+boost+gauge
Reply #14August 22, 2007, 09:08:08 am
« Reply #14 on: August 22, 2007, 09:08:08 am »
Those gauges are the shiznit!!!
I figure I can get, volts, water temp, boost, egt, oil press and oil temp all combined on 3 gauges for $500.00 shipped!
That's awesome!!
