Author Topic: ARP Part Numbers  (Read 23486 times)
April 26, 2007, 07:12:29 pm
subsonic
  • 1836
ARP Part Numbers
« on: April 26, 2007, 07:12:29 pm »
ARP part #s
Head Studs..........................251-4701 (yes, the catalog will show them as being for a Ford Cosworth Sierra/Escort!)
Main Studs...........................204-5402
Con Rod bolts 1.6 and 1.7......104-6002
Trans ring gear bolt kit 020 ...204-3001
Oil pump bolts.......................661-1014
Hope this helps
The head studs are the ones that were reccommended on this site. They should fit both 1.9 and 1.6. Correct me if I am wrong.
Same deal with the main studs. Got the info from here.
Con rod bolts, I sent my rods to ARP for them to check and find correct replacement size. This is what they reccommend. I would have sent in 1.9 rods but no one sent me any. I will pass along my contact info at ARP if someone wants to send some. These rod bolts are for the 1.6 and 1.7. I was told they offered about an additional 20,000 psi of strength and a much greater shear strength. I do not know if they will fit a 1.9
The trans ring gear bolt kit is for the 020 tranny's.
The oil pump bolts are direct replacement for the bolts out of my pump. I do not know if these are the same size as the newer 36mm pump people are talking about here on the site. Anyone know if the 36mm uses different size bolts?
All above refer to IDI.  The oil pump was from mid to late 80's hydro TD.
A new style of headstuds are available Click here for more info
« Last Edit: November 26, 2010, 03:30:56 pm by Vincent Waldon »
Reply #1April 26, 2007, 08:42:15 pm
foxracer1
  • 991
ARP Part Numbers
« Reply #1 on: April 26, 2007, 08:42:15 pm »
finally some concrete numbers
Thanks!  :D
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #2April 29, 2007, 07:38:07 pm
ARP Part Numbers
« Reply #2 on: April 29, 2007, 07:38:07 pm »
what are these numbers for? 1.6 & 1.9's non TDI?
Reply #3December 09, 2007, 01:47:49 pm
dillenger1
  • 777
ARP Part Numbers
« Reply #3 on: December 09, 2007, 01:47:49 pm »
Is it true there are two seperate lengths?Somewhere i heard you need to use a spacer in some cases.You sussposed to be able to tell by a c or s cast number.
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #4December 09, 2007, 08:27:17 pm
subsonic
  • 1836
ARP Part Numbers
« Reply #4 on: December 09, 2007, 08:27:17 pm »
Quote from: "dillenger1"
Which part are you asking about?
Reply #5December 23, 2007, 05:59:18 pm
dillenger1
  • 777
ARP Part Numbers
« Reply #5 on: December 23, 2007, 05:59:18 pm »
head bolts
Reply #6December 27, 2007, 09:59:42 pm
subsonic
  • 1836
ARP Part Numbers
« Reply #6 on: December 27, 2007, 09:59:42 pm »
I am not sure about that.  These numbers are for studs though.
Reply #7January 03, 2008, 05:46:03 am
ARP Part Numbers
« Reply #7 on: January 03, 2008, 05:46:03 am »
What about TDI head studs?
Also, do any of the others, (main, rods, etc) apply to the TDI?  I know it's been discussed before but it's too many posts ago....  :P
Reply #8January 03, 2008, 09:25:46 am
subsonic
  • 1836
ARP Part Numbers
« Reply #8 on: January 03, 2008, 09:25:46 am »
No idea.    I contacted ARP directly for my questions.  I will try and look up the guy's contact info so you can get it right from the horses mouth.
Reply #9February 02, 2008, 12:36:22 pm
ARP Part Numbers
« Reply #9 on: February 02, 2008, 12:36:22 pm »
I need to buy some con rod bolts for a 1Z TDI as well, and am looking to go ARP if the price is right, otherwise in with the stock ones.
any p/n's appreciated! thanks!
Reply #10February 02, 2008, 01:32:45 pm
subsonic
  • 1836
ARP Part Numbers
« Reply #10 on: February 02, 2008, 01:32:45 pm »
The contact info for the tech I used at ARP:
Chris Brawn  1-805-525-1497
He was very helpful and knew what he was talking about.
I was able to get a better price however through  headbolts.com.  If the guy did not have the part he would order it.  He was cheaper than summit.
Reply #11February 26, 2008, 11:53:27 am
subsonic
  • 1836
ARP Part Numbers
« Reply #11 on: February 26, 2008, 11:53:27 am »
Just to let everyone know, I just picked up a set of ARP main studs for my 1.6 from http://www.headbolts.com
My walking out the door price was 100 bucks.  Cheaper than 118 plus shipping from Summit.
Reply #12February 19, 2009, 10:07:24 am
one_tinted_tail
  • 22
    • http://www.CMLUA.com & www.hourofthetime.com
ARP Part Numbers
« Reply #12 on: February 19, 2009, 10:07:24 am »
before asking for specific part numbers for 1.6 TD head studs, i searched and found this thread, thanks.
being that ive done things the hard way many times and still do from time to time, I wanted to confirm the validity of the claims posted here. I will provide a cut&paste I just received from ARP.
Brian,
 The part numbers you have provided are not listed for that specific application. I do not have any information regarding if these parts numbers you have given me will work for your application. The head stud kit in question is listed for a Ford Cosworth Sierra/Escort with a 2.0L DOHC engine. The studs in that kit are 12mm x 1.75 and are 5.400” long overall.
 As I mentioned before I would need the calculation sheet to be filled out in order for me to verify if the part numbers you have provided (for the head and main studs) are correct for your application. As for the rod bolts, ring gear bolts and oil pump bolts we would need to know the dimensions of the factory bolts to see if the part numbers you have provided match up.
Regards,
Zac
I did get this calculation sheet on a previous email attachment from ARP, however that would require me to have more downtime with the car apart in my garage which im trying to avoid.
Im not saying that the PN's listed above wont work, but as you can read from ARP, confirmed it is not.
So does anyone have proof positive BTDT with corresponding PN's for ARP 1.6TD head studs?
thanks.
My mother named me Brian;
Ive owned many VAG cars but currently have it narrowed down to my 'UrSula' a '95 Audi S6 (dahlback RS2'd & then some) and 'Henryetta' an '85 Jetta TD whose peppy on the veg and is as pretty as her name.
Reply #13February 19, 2009, 10:36:20 am
ARP Part Numbers
« Reply #13 on: February 19, 2009, 10:36:20 am »
There are probably over 100 threads of different builds here with people using that part#. Head Studs..........................251-4701
GL with your build Zac.
Start up a thread as you go so we can help where needed. :)
Reply #14March 15, 2009, 02:40:33 pm
Jettagli16v
  • 344
ARP Part Numbers
« Reply #14 on: March 15, 2009, 02:40:33 pm »
Bump to keep the data at the top!
Just bought a set from Summit Racing on friday.
They are up to $130 by now, but still well worth it.
-Brad
