Author Topic: no alternator  (Read 6885 times)
Reply #15May 06, 2007, 06:32:12 pm
tylernt
  • 344
no alternator
« Reply #15 on: May 06, 2007, 06:32:12 pm »
Quote from: "jtanguay"
the alternator is a rotating mass though... surely you could gain more revvability
Oh I agree the removing the alternator entirely will gain some HP -- not only the rotating mass, but also the extra friction on the V-belt. But a cutout swich will not do anything about those. You'd have to get a smaller V-belt to go around just the crank and WP and use shims to tension it, which is a pain and wears out the belt faster.
Reply #16May 06, 2007, 07:43:21 pm
no alternator
« Reply #16 on: May 06, 2007, 07:43:21 pm »
Once the alternator "self-excites" it's pretty much off to the races, although in the old days of bulbs (before the red LED) a burnt out bulb was often the cause of the battery going flat ie no output from the alt... maybe it would still work.
I'm sticking to the my story... yes the altenator does produce all current when the car is running (that's why your volt meter jumps from 12V (battery voltage) to 14V (alternator) when you start the car) but a diesel during the daylight has very little demand for current.... the gains by turning off the alternator are likely to be slight (unless the headlights are on, the blower is running, or the rad fan is on).  My guess is that a large part of the omph you see running without an alternator is not having to spin another shaft with a fan on it.
Reply #17May 06, 2007, 08:32:22 pm
no alternator
« Reply #17 on: May 06, 2007, 08:32:22 pm »
Quote from: "Vincent Waldon"
I don't think that will work. The LED is tied to the exciter wire. I'm actually driving my car without the exciter wire even hooked up and it's charging fine
Reply #18May 06, 2007, 08:42:13 pm
no alternator
« Reply #18 on: May 06, 2007, 08:42:13 pm »
yup that would have been my guess... generators were much more sensitive to that than alternators.
Reply #19May 07, 2007, 12:43:40 pm
Black Smokin' Diesel
  • 656
no alternator
« Reply #19 on: May 07, 2007, 12:43:40 pm »
Never thought about the fan. An old alternator with worn bearings will also produce drag. Most MK2s and later vws' have DRL. Albeit working at only 90% or their capacity, it still needs a bit of current.
So killing the alt by interrupting power going to the battery will cause premature death and interrupting the exciter wire won't work.
I was looking at an AC compressor with a magnetic clutch pulley. It's a rather simple design. One two prong electrical connector and the clutch system. Main problem with this is the size of the compressor pulley. Mated to the alt, it would rev a lot less.
Reply #20May 07, 2007, 01:16:22 pm
tylernt
  • 344
no alternator
« Reply #20 on: May 07, 2007, 01:16:22 pm »
How about using the smallest alt possible (55A as I recall) and grinding down the fan blades a bit? Switching to a serpentine belt should reduce belt friction a lot too. V-belts are very draggy.
Reply #21May 07, 2007, 04:01:09 pm
  • 656
no alternator
« Reply #21 on: May 07, 2007, 04:01:09 pm »
Quote from: "tylernt"
I think you'd see better performance with simply going with the serp belt setup. It can't be that hard to switch to a serpentine setup without using a MK3 alt. Simply swap the pulleys for the crank, waterpump and alt. If you got AC and PS, I think you're screwed (but if you're looking for less drag, you probably dumped them anyway :P ).
Reply #22August 26, 2007, 07:29:45 am
Zulfiqar
  • 254
no alternator
« Reply #22 on: August 26, 2007, 07:29:45 am »
well - according to the workings of the regulator and some silly experience, the bosch alternators give no load once the battery voltage climbs up to 14.1
Over here we call them bosch ones easy going alternators, when charging they will load up the engine and when purpose fulfilled they will freewheel, unlike the jap hitachi and denso ones which constantly have a brake applied on the engine - and also tend to overcharge the battery if you only use your car in daytime
Diesel IS the future
Reply #23August 26, 2007, 09:36:54 am
  • 656
no alternator
« Reply #23 on: August 26, 2007, 09:36:54 am »
Quote from: "Zulfiqar"
Overcharging the battery? wow that's no good :?
Reply #24August 26, 2007, 11:31:21 pm
Zulfiqar
  • 254
no alternator
« Reply #24 on: August 26, 2007, 11:31:21 pm »
isnt it, it tends to boil the battery and reduce its service life.
