Author Topic: ARP/Raceware PNs  (Read 45586 times)
Reply #15June 19, 2006, 06:50:26 am
jackbombay
  • 599
ARP/Raceware PNs
« Reply #15 on: June 19, 2006, 06:50:26 am »
D'oh, I read the previouos posts too fast and confused the 2  :oops:
Reply #16August 25, 2006, 02:53:44 am
Audi80
ARP/Raceware PNs
« Reply #16 on: August 25, 2006, 02:53:44 am »
Will these ARP studs need retorque after ~1000km, like stock bolts need.
Reply #17August 26, 2006, 11:36:03 am
935racer
ARP/Raceware PNs
« Reply #17 on: August 26, 2006, 11:36:03 am »
No I don't re torque them after 1000miles, nor do I retorque the stock ones after 1000miles, seems to eliminate early HG failures.
Reply #18August 26, 2006, 03:31:00 pm
ARP/Raceware PNs
« Reply #18 on: August 26, 2006, 03:31:00 pm »
Quote from: 935racer
Yeah I have switched to ARP hardware over raceware. I use the ford cosworth headstuds for the 1.6 and 1.9 idi engines as well as the tdi's. I use their mains and rod bolts as well. The thing I really like about the arps the most (besides better availability and cheaper price) is that they have a 5mm hex head on them so you can spin them in or out really easy.
Do you have any part #'s for 1.6 head studs from ARP?  Considering about switching to them to eliminate possible HG failures from stretch bolts. :)
Reply #19August 26, 2006, 04:44:36 pm
935racer
ARP/Raceware PNs
« Reply #19 on: August 26, 2006, 04:44:36 pm »
204-5402, unless your head is completely straight or you are running over 35psi I wouldnt really bother, not a bad idea, but with a straight head and block deck,  and new stretch bolts its pretty hard to blow a gasket.
Reply #20August 27, 2006, 12:21:46 am
Audi80
ARP/Raceware PNs
« Reply #20 on: August 27, 2006, 12:21:46 am »
204-5402 are main studs. I used 251-4701 for head studs.
I retorqued after ~800km and hg lasted 15 minutes after that :shock: A couple of runs at 30psi with cheapo hg :roll: Well, itīs time to change to aaz metal gasket...
Reply #21August 27, 2006, 10:41:31 am
935racer
ARP/Raceware PNs
« Reply #21 on: August 27, 2006, 10:41:31 am »
Quote from: Audi80
Yes you are right, 204-5402 are mainstuds, and the 251-4701 are the headstuds, I just looked at an old box here and thought it was a headstud box not a mainstud box :oops:
Don't retorque your head after its running, seems to shift the gasket around and sometimes cause failures. Too bad its the factory spec, I've had to fix a lot of headgasket jobs where the owner put it all back together than soon after the re torque they blow a gasket.
1.9 metal HG never hurt 8)
Reply #22August 27, 2006, 10:20:20 pm
  • 2926
rod bolts
« Reply #22 on: August 27, 2006, 10:20:20 pm »
Anyone got part numbers for ARP rod bolts... for the 1.6TD?
Reply #23August 28, 2006, 07:21:05 am
Audi80
ARP/Raceware PNs
« Reply #23 on: August 28, 2006, 07:21:05 am »
Got it running with metal gasket. Seems to work with mech head too :D
Reply #24September 22, 2006, 11:09:38 am
  • 2926
ARP rod bolts
« Reply #24 on: September 22, 2006, 11:09:38 am »
 I called ARP and they had no idea. They want the length, thread size and under head length.
 Thanks for the head stud and main stud numbers.
 One more number and they'll all be listed in this post, for the next person who is searching.
Reply #25December 13, 2006, 02:10:11 pm
Audi80
ARP/Raceware PNs
« Reply #25 on: December 13, 2006, 02:10:11 pm »
How long are main studs? I need a little longer studs than stock, but I canīt find any measurements :? Studs should be ~100-110mm long.
Reply #26March 01, 2007, 04:11:03 pm
subsonic
  • 1836
ARP bolt numbers
« Reply #26 on: March 01, 2007, 04:11:03 pm »
So,
we have the ARP numbers for the:
Headstuds-------251-4701
Main studs------ 204-5402
Con Rod bolts---???-???
Has anyone determined what the con rod bolt numbers are yet?
Reply #27March 03, 2007, 12:53:55 pm
stewardc
ARP/Raceware PNs
« Reply #27 on: March 03, 2007, 12:53:55 pm »
Are the 1.6 and the AAZ the same?
Reply #28March 03, 2007, 01:09:57 pm
SMOKEYDUB
  • 630
ARP/Raceware PNs
« Reply #28 on: March 03, 2007, 01:09:57 pm »
I am very interested in upgrading my arp 12mm stud kit to a 13 mm kit. I just want some extra clamping force. Anyone know of a vehicle or part number that would use 13mm headstuds that would fit our blocks? I know i have to drill out and tap the block for the 13mm setup ( when i say I, I mean the shop).
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
Reply #29March 03, 2007, 01:13:02 pm
SMOKEYDUB
  • 630
ARP/Raceware PNs
« Reply #29 on: March 03, 2007, 01:13:02 pm »
is anyone going to finally sticky this thread?
(courtesy of GILES)
