Author Topic: How to determine notches regarding head gasket type  (Read 38555 times)
Reply #75February 17, 2014, 10:04:21 am
Mark(The Miser)UK
  • 1557
Re: How to determine notches regarding head gasket type
« Reply #75 on: February 17, 2014, 10:04:21 am »
This argument is kind if metaphysical. It is no more relevant than arguing about how many fairies can dance on the head of a pin.
Has anybody here actually put in a 3 notch when a one notch was called for????
Well I have. I did that once when I did not have the correct "notch" in stock. Fresh motor that I wanted to put some miles on. I ordered the 1 notch and drove the car for over a month with the 3 notch before I swapped out the correct gasket. I was expecting more power, less smoke, better starts, and better mileage. I can not attest to cold start performance because it was not cold here then, but I noticed NO DIFFERENCE. Nothing, Nada.
It did not feel faster, did not start better, did not smoke less, and the fuel mileage did not go up.
So I ask you how important is it really?
Argument promotes understanding... Reinforcement for those who already understand, and understanding for those who don't.
Dictatorial stifling of debate, by the use of the Drone like weapon of banning everyone who doesn't agree with the party line or 'The One' smells of Communism, Fascism etc, and we don't want that, do we!
Re the thicker than necessary gasket experiment:
 Cold weather may have shown something.
 Having a fresh engine, probably meant that even the lowered compression was better than an un-rebuilt, but otherwise  functional high mileage engine...
Still, useful information.
Mark-The-Miser-UK
Reply #76February 18, 2014, 04:57:10 am
head gasket vs compression
« Reply #76 on: February 18, 2014, 04:57:10 am »
A 1-notcher is ~.87mm thick, a 3-notcher is ~1.02
V1 / V2 = rC
397 / 17.26 = 23.0
398 / 18.28 = 21.77
21.77 / 23 = 5.3% change
Considering other variables,  5.3% change in compression ratio might be hard to detect.
Compare to a midlife engine: let's say 350psi... 350/450 = .777  or 23% change
Reply #77February 18, 2014, 05:10:31 am
« Reply #77 on: February 18, 2014, 05:10:31 am »
V1 / V2 = rC
397 / 17.26 = 23.0
398 / 18.28 = 21.77
Well not according to what sauerkraut had on his engine that was fresh. The HG made for harder starting and was fixed when he went to the 1.9 head *with larger swirl chambers* and the correct gasket. Page 6 of the link shows his problems.
Reply #78February 18, 2014, 07:13:10 am
« Reply #78 on: February 18, 2014, 07:13:10 am »
Ja, I don't doubt that... I'm mostly throwing numbers into the mix, particularly comparing HG volume vs wear.
We're dealing with nuanced assessment in a dynamic environment, and opinion is surely gonna vary.
Reply #79February 18, 2014, 07:38:54 am
92EcoDiesel Jetta
« Reply #79 on: February 18, 2014, 07:38:54 am »
I only asked you to prove what you said man..
You said no because we are not worth your time..
Why do you post here then??
Enough. You are putting words into his mouth, he never said anyone here was not worth his time. Last warning.
Can a moderator give warning to another moderator? Is there a moderator pecking order?
8v was demoded a few months ago. His entire account deleted hence his new account has a "!" at the end.
Really!!! What happened?
Nobody want to tell me what happened? What happened to 8v-of-fury's posts? They seem to be all gone. Did he do a Libby and  deleted every post he ever made? That would be a shame since he contributed a lot to this forum. Is that "feature" still available? What's next? Is Libby going to do a second round of total delete?
Reply #80February 18, 2014, 03:24:59 pm
« Reply #80 on: February 18, 2014, 03:24:59 pm »
All the fracas got scrubbed.
He globally deleted?... well, that sucks.
Edit: seems some stuff still there.
« Last Edit: February 18, 2014, 04:02:40 pm by TylerDurden »
