Author Topic: Oil cooler questions. Looking at universal setup.  (Read 14575 times)
April 08, 2013, 11:15:35 am
GTFORZA
  • 29
« on: April 08, 2013, 11:15:35 am »
Locking at the kit from ecs. http://www.ecstuning.com/Volkswagen-Jetta_I--Diesel/Engine/Cooling/Oil_Cooler/ES1892558/ does anyone know if this would replace the factory oil cooler on my 84 1.6 cy turbo diesel or does it go in the place of the filter and the filter goes on the bottom of it. I would prefer to separate the oil cooling and the coolant system for prevention of the factory oil cooler causing contamination. I have some other upgrades planned that would put more stress on the motor. I've already figured out an air to water intercooler setup, made a twin fan shroud for use with twin low-pro fans. Just wanting some insight. Any info would be great.
Reply #1April 08, 2013, 11:20:55 am
GTFORZA
  • 29
Re: Oil cooler questions. Looking at universal setup.
« Reply #1 on: April 08, 2013, 11:20:55 am »
Reply #2April 08, 2013, 11:29:11 am
GTFORZA
  • 29
« Reply #2 on: April 08, 2013, 11:29:11 am »
For some reason I think the oil filter is a standard size. Like 3/4-16
Reply #3April 08, 2013, 01:24:31 pm
« Reply #3 on: April 08, 2013, 01:24:31 pm »
You can use a Volvo sandwich plate, and an oil cooler from a bigger vehicle to accomplish the same thing for  less than half the cost.
Reply #4April 08, 2013, 02:00:24 pm
« Reply #4 on: April 08, 2013, 02:00:24 pm »
It looks like the sandwich plate and threaded shaft is included, but... $200!!?!?!?!!
You can get the sandwich plate + oil cooler + some high pressure hose and fittings for less than half that cost at summitracing.com,, but you won't get "blingy" stainless steel stuff (but you don't really need it anyway).
Or you could just go to a junkyard and find a Volvo 740 turbo, as mentioned, and probably pay $20 or $30 for the sandwich plate and decently sized oil cooler that is on the side of the Volvo radiator. The Mercedes 300d has a big oil cooler too.
I believe the VW actually does use 3/4" thread for the oil filter, not metric.
Reply #5April 08, 2013, 04:05:51 pm
GTFORZA
  • 29
« Reply #5 on: April 08, 2013, 04:05:51 pm »
Could I just remove the factory cooler and reuse the old 3/4"-16 cooler adaptor?
Reply #6April 08, 2013, 04:09:43 pm
« Reply #6 on: April 08, 2013, 04:09:43 pm »
Going the Volvo route, you'd want the Volvo  block nipple.  I didn't think of that, and had to buy an expensive die  to shorten  the air/water one.
Reply #7April 08, 2013, 07:22:35 pm
wolf_walker
  • 1205
« Reply #7 on: April 08, 2013, 07:22:35 pm »
Been a guy on vortex in the A1 parts section selling external oil cooler setups for awhile now, worth looking up.
The Volvo bit is good stuff. Almost anything is better than the oil/water factory junk.
Mentat Text Two
Reply #8April 08, 2013, 08:08:39 pm
« Reply #8 on: April 08, 2013, 08:08:39 pm »
Now what of ones with a thermostat? Necessary? You don't always want your oil as cold as possible do you?!
Reply #9April 08, 2013, 08:39:26 pm
« Reply #9 on: April 08, 2013, 08:39:26 pm »
Right on 8v, the one libby found at SUmmit Racing was perfect. It was also only 30.00 IIRC.
Reply #10April 08, 2013, 10:20:38 pm
wolf_walker
  • 1205
« Reply #10 on: April 08, 2013, 10:20:38 pm »
You can run all the oil cooler you want as long as there's a t-stat, all factory setups will have one, Volvo had it in the adapter on the filter flange, mine has an external one that is pretty common on aircraft and everything else.  I consider them nice to have on a NA, and mandatory on a turbo.
http://forums.vwvortex.com/showthread.php?5774791-FS-Oil-Cooler-Setup-Temp.-Sandwich-and-Radiator
Mentat Text Two
Reply #11April 09, 2013, 05:06:09 pm
« Reply #11 on: April 09, 2013, 05:06:09 pm »
I have read some accounts of dudes not runnin a thermo.. And they claim (with an oil temp gauge) no effect in warm up times.
Reply #12April 09, 2013, 09:16:26 pm
wolf_walker
  • 1205
Re: Re: Oil cooler questions. Looking at universal setup.
« Reply #12 on: April 09, 2013, 09:16:26 pm »
If ambient is enough and the cooler is small enough, and the motor makes enough heat, sure I'd believe that. But I personally will not have a car I can't drive anytime, anywhere. I've been on the road in cold enough weather in a blizzard that my na 1.6 couldn't maintain normal op temp and heater output at sustained 3rd gear crawling through snow. Too easy to run a tstat to not do it in my book.  But I'm nitpicky.  A couple UOA's would tell the tail.
Track or play car would be another story.
Sent from my SCH-I535 using Tapatalk 2
Mentat Text Two
Reply #13April 10, 2013, 06:07:46 am
« Reply #13 on: April 10, 2013, 06:07:46 am »
I used a cooler that was 13x7x1 with 1/2" lines. If you don't have a thermo on that cooler you oil will have a hard time getting up to temps.
Libby found one for around 30 dollars that bolted on perfectly in place of the stock deal. It has a thermostat in it. It was from summit racing, but I cannot remember who made it. As a new part I used I fully endorce it if you find it.
Reply #14April 10, 2013, 07:28:28 am
