Author Topic: "resistance"felt when turning over  (Read 2992 times)
March 18, 2008, 06:18:28 pm
dillenger1
  • 777
« on: March 18, 2008, 06:18:28 pm »
Ive just assembled my bottome end with new pistons and rigs in a brandnew 40 over bore.Ive done the bottom end and rod bearings also.I used the 6 piece number 3 on the mains,as well as a 36mm oil pump.When measuring piston protrusion i was turnng her back over to tdc and i noticed a slight "resistance"or drag when coming up to just about tdc for no.1.I was thinking maybe the baffle on the oil pick-up is rubbing.Its right around where the ridge used to be before machining.I didnt notice it before i put the pan on,does anyone have any ideas?Its very slight just enough to stop fluid piston travel.
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #1March 18, 2008, 06:52:00 pm
dillenger1
  • 777
Re: "resistance"felt when turning over
« Reply #1 on: March 18, 2008, 06:52:00 pm »
Quote from: "dillenger1"
Ive just assembled my bottome end with new pistons and rigs in a brandnew 40 over bore.Ive done the bottom end and rod bearings also.I used the 6 piece number 3 on the mains,as well as a 36mm oil pump.When measuring piston protrusion i was turnng her back over to tdc and i noticed a slight "resistance"or drag when coming up to just about tdc for no.1.I was thinking maybe the baffle on the oil pick-up is rubbing.Its right around where the ridge used to be before machining(the resistance).I didnt notice it before i put the pan on,does anyone have any ideas?Its very slight just enough to stop fluid piston travel.
Reply #2March 18, 2008, 09:40:44 pm
« Reply #2 on: March 18, 2008, 09:40:44 pm »
So no head on it?
Reply #3March 18, 2008, 09:43:42 pm
westcoaster
« Reply #3 on: March 18, 2008, 09:43:42 pm »
Errrmmmm.....
First thought is to take it all apart again as it would probably be easier and cheaper now than after it was in and running destroying parts in the process....
Second thought is to start pulling parts off one at a time until the problem is isolated.
First, off comes the oil pump, then the pistons one at a time....
I'm assuming you used some sort of assembly lube?
If the head is on would one of the valves be making contact with a piston top?
Just starting off the discussion for you :)
'87 suzuki samurai with a 1.9 AAZ TD transplant
Reply #4March 19, 2008, 12:55:33 am
« Reply #4 on: March 19, 2008, 12:55:33 am »
Does it only do it on the no.1 cylinder?
Reply #5March 19, 2008, 03:00:39 am
dillenger1
  • 777
« Reply #5 on: March 19, 2008, 03:00:39 am »
The head is off,It feels like the cylinder bore gets slightly smaller when your coming up to tdc.like there is still a ridge or something.I did use assembly lube.Its not much resistance at all just enough to stop a fluid movement.Doesnt feel like metal to metal contact.
Reply #6March 19, 2008, 04:38:43 pm
dillenger1
  • 777
« Reply #6 on: March 19, 2008, 04:38:43 pm »
It went away!I dont know if the a ring wasnt set or what.Theres isnt anything on the intermiadiate shaft assembly to get in the way, is there?I rotated it so the key is at 12 oclock.Then i rotated the crank one more time and it was "freed".I almost wanna open it to see what happened.It seems odd to me.
Reply #7March 19, 2008, 07:19:34 pm
« Reply #7 on: March 19, 2008, 07:19:34 pm »
I wonder if it wasn't the vacuum pump causing that? You know...the diaphram stretching and stuff. :?:
