Alright here is whats up. Its -18c here right now. I started it up earlier to move it in the driveway, just a whore to start. I went with my brother down to his shop he works at to spend the day doing stuff to his car, came back and went to dinner in my car. so the car sat in -18c all day pretty much. From noon, until I started it again at 7:30pm. It started fine, ran like ass, but started fine. It also missed for quite a bit while driving it.. always does.
Kevo its the injector type. Got it from Prothe
lol. I guess i'll be checking compression in the next few days.
Glow-plugs all check out, and the starter is definitely cranking REAL quick. so i rule cranking speed out too.
Mark, you are a rambling man.
lol lemme see if i can follow you. It may be too advanced, but I tried it at 0.040-0.035inch (1.00mm-0.90mm) and it did the same things.. if not it was worse to start when retarded.
You want me to try timing to 0.030? 0.030 inch = 0.762 millimeters I think that will be a tad TOO low, wont it? what do you mean by I am operating nearer 125bar as opposed to 135bar?
I have messed with the max fuel screw quite a bit, but i do believe I have it in as far as I can possibly have it.. I have the other two "idle" adjustments practically bottomed out so I can have the fuel screw in as far as possible without a hanging idle! lol
Also the motor is using zero oil. This happened prior to my last oil change and I am now running a 5w40 full synthetic.. and it is still not using any. I wouldnt say it is blue like your text there mark lol.. definitely smells like un-burnt diesel as opposed to oil.
