#330
by
on 22 Aug, 2011 18:30
I adjusted some valves last night. 6 of 8 needed adjusting. I have seen a decrease in egt. Not much but I will take every degree I can :>
I also replaced the front mount my wife ripped out with the BFI industries G60 front mount and worlds of better. I didn't get the trans mount in or the rear insert. I would like to do the trans mount next as it is poly stage 1. Any suggestions on how to get at it, or the easiest way to change that mount in an MK2?
#331
by
RadoTD
on 22 Aug, 2011 18:39
I don't remember how I replaced my trans mount last time, but I do remember that I took out more bolts than I needed to! I think if you just undo the 17mm bolt on top, the couple on the bottom of the mount, you can lift the trans enough to pull it out that way
And are you saying that BFI's G60 mount is better than the stock? Was it stiffer or softer?
#332
by
on 22 Aug, 2011 18:43
Stiffer than the stock rubber mount I had. The wife ripped mine out so it was a lot better. But even before she did that I think that this mount of theirs is a ton better than my whipped on stock one.
#333
by
on 25 Aug, 2011 11:48
Whoa! Out of curiosity, what's the longest you've held it 1500+ before?
like probably a minute before..
#334
by
on 03 Dec, 2011 08:43
Well, for the celebration of the birth of Christ I am sending back the Giles pump to see if he has anymore magic to do to her.
I took it off last night and replaced it with a 12mm Cummins pump. I have it timed and hopefully after I eat and clean the chimney I will have it running. If not I will have to get it back on before work Monday.
On another note as I was reading my stuff above, I did get the poly engine and trans mounts. I installed both, drove 1/2 mile, turned around drove another 1/2 mile home, and took the rear engine poly mount out. Too much vibration at idle-2,000rpm, but running down the road it was awesome. I left the poly trans mount in and it has worn in well. It was still a bit much at first, but now it only vibrates bad at idle.
#335
by
RadoTD
on 03 Dec, 2011 17:47
Good to know about the poly mounts... what are you running up front?
#336
by
on 03 Dec, 2011 18:22
Look at your and my posts up maybe 4 posts, starting at post 330...hint, G60 bfi mount
Got it running, tons of snap, but we will see about power. I haven't got to take it out for the road test yet. I have it timed per Giles recommendation to right about 1.28mm. Still a bit of white at cold idle, but seems to be ok. I always had a little white even with the Giles pump.
#337
by
RadoTD
on 03 Dec, 2011 19:34
Haha oh man, that's embarrassing!
#338
by
on 03 Apr, 2012 05:19
#339
by
on 10 Apr, 2012 18:38
Finally starting Round 2 of this.
Here is what I have decided. I have around 300.00 of parts in an autohaus cart. I paid for 2 cylinderheads for my 1.6. I am going to do another 1.6. Then when things simmer down I will do an aaz. I figure I will have around 1,400.00 in the build that I am going to do and a special cylinder head will be made. I also will be glueing in the precups. I might be running an N/A head as the precups are supposed to be a tick smaller than the TD for a little less (read .5) compression. I will start the ROUND 2 thread when it all comes together.
#340
by
on 10 Apr, 2012 19:22
Would a smaller pre-cup (thus less space) not actually raise compression? (albeit .5)
Sounds good to me man, seeing as how you hate the ALH so much lol.
#341
by
on 11 Apr, 2012 04:58
Yep...once again I wrote what I am meaning in reverse. The TD precups are supposed to be the tick smaller and yeild the .5 point of compression. From what others have said the TD and 1.5 had the same precup. I know that precups have different faces as one measures 30mm across and the other 32mm. The N/A has the 32mm face as far as I can tell and should give me a bit more surface area for my "glue" and the head to hold onto...I hope.
#342
by
on 16 Jun, 2012 14:32
Just got the call from the engine borer... the crank and bores were fine. He was considering honing and putting it back since he couldn't find pistons for it....but I had given him pistons to bore the motor to. He eventually found them. He said it would be about a week. He also found a sleeve for the intermediate shaft. THe mains and rods he said showed little to no wear at all and I could reuse the thrust washers
I also took apart the head last night. I will hopefully be sending it and the IP out tomorrow. FULL PORT and undercut valve job for the head and GILES for the IP and injectors...you only live once right? I am breaking the bank for this so I hope all goes perfectly and no problems or do overs. I am hoping with the Giles IP and injectors and the fully ported head to make some more HP over stock, but still get some mileage. I will post some before and after head port pics as soon as I get it back.
Way back when, I was hoping that it all went perfectly...it didn't. I have posted the precup pics and will add the block pics soon. Should have the engine back soon and I have planned to have it running by the first week in July. It will depend on the machinist as I am pretty much ready to go on with this.
Side note, anyone have absolutely no issues with their pic hosters? Myspace just isn't really reliable as you can see.
#343
by
on 16 Jun, 2012 17:52
#344
by
on 16 Jun, 2012 21:25
I see u do not believe in them but where can I buy a douche bottle XD
