Maybe someone can answer my question on the speedo sender wires ?
http://www.vwdiesel.net/phpBB/viewtopic.php?t=18674Last night I got closer to first start ;-)
I got some radiator support bushings from a local radiator shop ran by an OLD guy... the local Chrysler dealer said tough luck on buying then as 1992 is VERY old and discontinued long ago. At first the old dude said tough luck too.... I explained about my VW diesel in a Dodge and it peaked his interest... then he remember he had a bucket stashed someplace. There were 2 different sized. We showed me the smaller diameter and I said "That's it !" but when I saw the larger, it looked good too, so I took 2 of them. He told me to bring him back $1 for them when I could as I only had plastic and checks in pocket. I tried to install them, but they were too big and he was closed....
I then took some Never Seize and applied to the ends. I used a 3/8" socket extension to "pull" them in from the ends.. worked perfect !!
Here's the rope from yesterday... to measure the belt length.
To block the open port on my head
I cut 2 pieces of 1/8" aluminum stock and shaped to the rough shape.
Then I welded them together
and sanded the mating surface flat on my bench belt sander. You will also see the 1.375" to 1.75" adaptor I am making. Notice the ridge at one end of the tube. My turbo has about a 1" discharge opening for the pressure side. The intake manifold is about 1.75". Since they will be under pressure, I welded the ridge to keep the hose from slipping off.
Here is the other end of the reducer. It will also be a 100 degree elbow.
The little plates will seal the gap where it is reducing.
I had to stop welding as my Miller automagic helmet went all black, I thought I could still weld, but it was completely blocking the light, not just the dangerous light.... I had not placed it in the sun for some weeks. It is inside the house in a window now.
