Oil return Line.
Pages:
4
Topic: Oil return Line. (Read 10725 times)
Reply #30
June 18, 2013, 09:18:15 am
Re: Oil return Line.
Reply #30 on:
June 18, 2013, 09:18:15 am »
191 199 354C
http://www.ebay.com/itm/VW-Mk2-Golf-Jetta-Rear-Motor-Mount-Bracket-1987-1992-/380282911684?pt=Motors_Car_Truck_Parts_Accessories&hash=item588aa0bbc4&vxp=mtr
Make sure it has suffix 'C'...
Reply #31
June 18, 2013, 11:57:06 am
One_punchmachinegun
Re: Re: Oil return Line.
Reply #31 on:
June 18, 2013, 11:57:06 am »
That's the one. Thanks. I will be going to the junk yard this weekend. Hopefully I find one of those. The guy that I talked to said that it would be fine to just modify the bracket. But I would feel more comfortable using the correct bracket. Maybe for the time being I will modify it if people don't see a problem with that.....
的f anyone hears my words but does not keep them, I do not judge that person. For I did not come to judge the world, but to save the world." Jesus Christ
Reply #32
June 18, 2013, 01:27:42 pm
Reply #32 on:
June 18, 2013, 01:27:42 pm »
If it were my rig, I'd get the real mcCoy... stressed aluminum castings being crack-prone when cut.
Reply #33
June 18, 2013, 02:06:52 pm
Reply #33 on:
June 18, 2013, 02:06:52 pm »
The suffix A and suffix B are also stock. One is for a gasser I think. Mine may have worked for you but I would hate to see it go and then you end up at the same spot you are in right now.
Round 2
Reply #34
June 18, 2013, 04:07:09 pm
Reply #34 on:
June 18, 2013, 04:07:09 pm »
I'm pretty sure 'C' is the one with the passage for the oil drain. The others have straight features.
Prothe/Hahns/Westport stocks em' but the castings look nasty to me.
Reply #35
June 18, 2013, 04:53:27 pm
One_punchmachinegun
Reply #35 on:
June 18, 2013, 04:53:27 pm »
Yes. that does, I would rather modify it than go with that.
I guess, I will then see that what kind of arm and a leg the dealer wants.
Now the guy that I talked to said that the TD and the 16v had the same bracket.. If this is true then, junk yard trip should do the trick.. But if its TD specific, then I am out of luck unless someone on here has a spare.
Reply #36
June 18, 2013, 05:03:15 pm
One_punchmachinegun
Reply #36 on:
June 18, 2013, 05:03:15 pm »
117.00 FREAKING DUCKS!!! My goodness.
I find it funny that dealers charge so much. How do they come up with these numbers.
Reply #37
June 18, 2013, 06:34:48 pm
Reply #37 on:
June 18, 2013, 06:34:48 pm »
The ebay one looked authentic, just ensure the seller is offering the 'C' version... they listed 'A' as an alternate part number. 'C' can be used in place of 'A' , but not the reverse.
Reply #38
June 18, 2013, 06:36:22 pm
One_punchmachinegun
Reply #38 on:
June 18, 2013, 06:36:22 pm »
I will look into that one.
Reply #39
June 18, 2013, 06:39:30 pm
One_punchmachinegun
Reply #39 on:
June 18, 2013, 06:39:30 pm »
I've been wanting to ask you, What days do you go? Its truely changed my life. I go Tuesdays and Thursdays.
Reply #40
June 18, 2013, 07:39:13 pm
Reply #40 on:
June 18, 2013, 07:39:13 pm »
The first rule...
Reply #41
June 18, 2013, 09:09:10 pm
One_punchmachinegun
Reply #41 on:
June 18, 2013, 09:09:10 pm »
Haha. Right right.
Reply #42
June 18, 2013, 10:43:11 pm
damac
Reply #42 on:
June 18, 2013, 10:43:11 pm »
I found one of these in the garage tonight.
1985 turbo diesel jetta
Reply #43
June 18, 2013, 10:49:23 pm
One_punchmachinegun
Reply #43 on:
June 18, 2013, 10:49:23 pm »
Oh yeah? Whatcha going to do with that thing?
Reply #44
June 18, 2013, 11:19:19 pm
damac
Reply #44 on:
June 18, 2013, 11:19:19 pm »
oops should have said i do not need to keep this. i have an mk2 85 jetta i am selling soon, that leaves me with rabbit and truck.
Pages:
4
Oil return Line.
