Author Topic: I am starting a 1.6TD build version 2, hoping for more than 40,000 miles :D  (Read 347674 times)
Reply #165July 14, 2013, 08:20:28 pm
Gizmoman
  • 1301
Congratulations Mr!
Only 39,996 miles to go and you'll beat your old record by a mile ;D
Reply #166July 14, 2013, 08:22:48 pm
Yep, it is off to a rough start.
Reply #167July 14, 2013, 08:35:26 pm
Congratulations Mr!
Reply #168July 14, 2013, 09:03:54 pm
Dakotakid
  • 1240
I would use a mirror and light (however it works for you) to carefully examine that plug hole (cast iron). Probably no problems. But..........examine it none the less. I would also be a bit concerned about ALL the others as well.
Make sure you check to see if any oil running out of the trans/engine seam (the small plug).
Reply #169July 14, 2013, 09:46:55 pm
Dakotakid
  • 1240
Additionally:
If you go with the block heater, spend a couple moments looking at how the particular heater bung/heater cord plug orients. Determine what is your best goal as far as electrical cord placement back there behind the turbo and downpipe.
I have installed some and then been irritated with an additional loop of cord in order to exit out the passenger-side of block (due to orienting it 180 degrees wrong).
I know it seems like small stuff, but small stuff matters. And, you can avoid a burned cord (which you only discover in the middle of a cold snap!).
Reply #170July 14, 2013, 10:00:00 pm
my issue is ive had a properly installed one blow out 1.5 years after install as the o-ring corroded.. had grease on it.. and pushed it out the block.. :( like they forgot the coating on the potmetal it was made from.. :( it was not a cheap crappy one.. never did that again on any of mine.. the 2 i have are og original vw ones.. still work and all.. have removable plug.. will not touch/remove or anything.. both 1.6 non hydro bottom ends.. 1 na, 1 td.. 12mm headbolts... so 82.5-86 parts... too bad aftermarket ones junk..
Reply #171July 15, 2013, 05:43:50 am
I have checked out the hole with a light and ran my finger around, seems good. The plug I have maybe vw. as it looks like good stuff and I had to pry it out of my aaz block as it would not come out. I am just using it to plug a hole as I already have a block heater installed from the last engine in the far passenger side hole. Both block heaters on the car have the removable cord, so it is a shot that they could be stockers. I don't know what but I remember the middle freeze plug didn't look seated compared to the rest of them. I hoped to be further along than this. I at least wanted to have the first 20 mile filter change. Oh well.
Reply #172July 15, 2013, 05:48:54 am
you did not replace after hottank??? all need replaced if hottanked.. weakens them...
Reply #173July 15, 2013, 06:18:04 am
They all need replaced if the block is tanked.  The two oil galley plugs and the plug at the end of the intermediate shaft should be as well.  The larger plugs are 36.6mm which is not a 'normal' size.  IIRC the galley plugs are 14mm.
Reply #174July 15, 2013, 06:33:12 am
called him just now.. they were.. sadly he also states/is thinking that one did not look to be in like the rest too. .:P opps... how we learn.. big mistake =  brain winkle..
Reply #175July 15, 2013, 06:51:04 am
my machinist did all the freeze plugs, oil plugs, IM bearings, and the oil squirters. I did the assembly of the rest of the block. I don't think I would have done any better as I am not a good freeze/welch plug installer. I will have it going again, hopefully tonight.
Reply #176July 15, 2013, 04:12:48 pm
https://www.dropbox.com/s/n9su0uexjzme746/VID_20130714_180256_514.mp4
There it is running its return voyage, before the freeze plug incident.
Reply #177July 16, 2013, 06:00:18 am
Can you guys see that video?
Reply #178July 16, 2013, 06:14:44 am
Gizmoman
  • 1301
Yes - sounds ready to rock
Reply #179July 16, 2013, 08:09:02 pm
CrazyAndy
  • 739
Yaaay living.
Won't say anymore; might jinx it.
