Author Topic: I am starting a 1.6TD build version 2, hoping for more than 40,000 miles :D  (Read 347533 times)
Reply #570April 16, 2026, 04:25:39 pm
Gee, I was running up one of the longer, more sustained hills in town and had it in second rather than third.  I felt it bump a couple of times and noticed the boost was at 10 psi.  Maybe I need to crank it up a bit.  I do have ARP head bolts on it.
What do you think?  Take it up to 12 or 15 before the wastegate opens?
Reply #571April 16, 2026, 06:58:13 pm
  • 2932
Heck yea.
Reply #572April 17, 2026, 09:14:40 am
Dennis Froelich
  • 258
Yep!! My 1.6 TD seen alot higher than that... My 79 would climb some steep hills around here.
79 Golf GTD
96 Golf GTD(TDI)
02 Golf TDI 2 door
Reply #573April 17, 2026, 07:33:01 pm
OK,  If it doesn't rain too much on Sunday, I will pop the hood and torque on a couple of those adjustment thing-a-mah-jiggies.
If I bump the boost up, I might not need to shift in the middle of the grade, doing that generally puts me in a no boost zone and in third.  Not great performance at that point.
Reply #574April 18, 2026, 07:21:00 am
Dennis Froelich
  • 258
You will be wondering why you didn't do it sooner!!
79 Golf GTD
96 Golf GTD(TDI)
02 Golf TDI 2 door
Reply #575April 19, 2026, 12:33:15 pm
I had such trouble with previous heads that when I finally got the hydraulic head I wanted to cautiously approach the boost level.  Now that I am confident that the head will hold pressure I will tweak the level up.  Will I be doing 30 psi?
Likely NOT!
Reply #576April 19, 2026, 07:30:28 pm
  • 2932
30psi boost didn't make me go faster. I think due to back pressure.
 I actually have more power with around 15-20 psi with the 1.6D.
Reply #577April 21, 2026, 06:29:37 pm
I think the adjustment is good.  12-14 psi @ 4300 in second.  Shifts between the gears seems better as the turbo holds the spool up better now.  Not going to futz with it anymore.
