Author Topic: sold out  (Read 51507 times)
February 09, 2005, 01:16:46 pm
Smog
  • 160
sold out
« on: February 09, 2005, 01:16:46 pm »
I got 10 sets of 1.6GTD nozzles (RA/SB engines )
and
25 sets of 1.9TD nozzles (AAZ engines)
85$can each set
add 10$ for fast shipping anywhere
I also carry the 0.205mm and 0.216mm nozzles for the TDI at 160$can
www.VEG-Injection-Service.com
1.6GTD nozzles (RA/SB )
1.9TD nozzles (AAZ )
0.205mm or 0.216mm TDI nozzles
TDI injection pump seal kit
IDI Pump shaft seal
Reply #1February 10, 2005, 10:23:39 am
Smog
  • 160
Re: TDI, 1.9TD (AAZ) and 1.6GTD (RA/SB) nozzles for sale
« Reply #1 on: February 10, 2005, 10:23:39 am »
Quote from: "Smog"
and
85$can each set
I also carry the 0.205mm and 0.216mm nozzles for the TDI at 150$can
I will wait for Redrotors to sell his 2 sets of AAZ nozzles before selling mine.  But the GTD are available
IDI Pump shaft seal
Reply #2February 15, 2005, 07:51:11 am
Smog
  • 160
sold out
« Reply #2 on: February 15, 2005, 07:51:11 am »
QuickTD, I just sent you COD your GTD nozzles. You should get them on wednesday or thursday
IDI Pump shaft seal
Reply #3February 15, 2005, 10:45:58 am
QuickTD
  • 1156
sold out
« Reply #3 on: February 15, 2005, 10:45:58 am »
Thanks, got your PM as well. Stay tuned for test results. I may have to manufacture some shims to set these up. The 2 spring nozzle holders take a different shim than the "normal" holders. Good thing I have a surface grinder. :D
Reply #4February 15, 2005, 03:35:59 pm
fspGTD
  • 1529
    • http://home.comcast.net/~vwgtd
sold out
« Reply #4 on: February 15, 2005, 03:35:59 pm »
So these are the 2-stage nozzles... excellent.  Smog, you da man!  :)
If someone could do a comparison of the 2-spring 1.9lTD setup vs. the 1-spring RA/SB, I would love to hear about it.  And did I mention I'd really, really like to see some hp/torque curve comparisons (either chassis dyno or g-tech with RPM sensing).
Jake Russell
Dieselicious Turbocharger Upgrade/Rebuild Kits
Reply #5February 15, 2005, 03:40:39 pm
fspGTD
  • 1529
sold out
« Reply #5 on: February 15, 2005, 03:40:39 pm »
To reiterate my test results of the 2-stage 1.9lTD setup vs the stock '84 1.6lTD... the 2-stage nozzles gave a nice boost (above 5%) up high, but were notably weaker below 3000RPM than the stock '84 1.6lTD 1-spring'ers.
Jake Russell
Reply #6February 15, 2005, 11:17:32 pm
QuickTD
  • 1156
sold out
« Reply #6 on: February 15, 2005, 11:17:32 pm »
Smog is selling nozzles only, not complete injectors. I plan on installing the RA/SB nozzles in a spare set of 1.9TD 2 spring injector bodies. If I don't like the way that it works I may try them in a set of single spring bodies or I'll simply remove the second stage spring from the 1.9TD injectors, that way I wouldn't have to bend the lines to fit the short 1.6TD injector bodies...
Reply #7February 16, 2005, 01:37:49 pm
Smog
  • 160
sold out
« Reply #7 on: February 16, 2005, 01:37:49 pm »
Quote from: "QuickTD"
Soon I will have a Poptester and I'll be able to sell complete injectors on an exchange basis.
IDI Pump shaft seal
Reply #8March 03, 2005, 09:23:40 pm
foxracer1
  • Authorized Vendor
  • 991
sold out
« Reply #8 on: March 03, 2005, 09:23:40 pm »
Ok let me get this straight will 1.9TD nozzles (AAZ engines) fit 1.6 turbo injectors? is there any benfit if they fit?
will putting the GTD nozzels on regular 1.6 turbo injectors be of any benefit? how about putting any of these on 1.6 n/a injectors? thanks for the help. also how come there isn't a company that makes aftermarket performance injectors for these engines?
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #9March 04, 2005, 06:54:38 am
Smog
  • 160
sold out
« Reply #9 on: March 04, 2005, 06:54:38 am »
Quote from: "foxracer1"
yes
1.9TD nozzles on 1.6TD engine SHOULD flow more fuel (no test done about it) and restore driveability/power/mpg on 15+years old injectors
1.6GTD nozzles on 1.6TD engine WILL flow more fuel and restore driveability/power/mpg on 15+years old injectors
the 1.6d injector body are the same as the 1.6td
how about putting any of these on 1.9td injectors?
It look like 1.6GTD nozzles on 1.9td engine can to do a great job
http://www.vwdiesel.net/phpBB/viewtopic.php?t=1039
because there is no need as you can tweak the pump to give more fuel. The point in changing the nozzles is more to restore the spray patern of the injectors; it will cure some of the smoke, bad mpg, bad idle,low power output. But the GTD nozzles will give more power than regular 1.6TD nozzles.
In fact there's no aftermarket performance injectors for the TDI; we sell injectors designed for other TDI model that produce more HP. We put BIGGER injectors on the TDI to trick the ECU; while he think he send 1mg/stroke, the bigger injectors push 1.5mg/stroke. On a TD, you just need to turn up the max fueling screw to do this.
Just to add to your confusion, I have GM 6.5L and 6.2L nozzles that will fit on 1.6D injectors..... (Redrotors tried this and told us it's not a performance upgrade)
IDI Pump shaft seal
Reply #10March 05, 2005, 06:07:37 pm
Smog
  • 160
sold out
« Reply #10 on: March 05, 2005, 06:07:37 pm »
I added a picture showing the inside of a 1.6td injector. I will show people how easy it is to swap the nozzles. If your set of injectors is leaking, they will need to be pop-tested for pressure setting.
As you can see, I will be able to get a limited amount of  "Bosio-Fratelli" 1.9TD nozzles from KermaTDI; but they will be more expensive at 100$can each set of 4.
IDI Pump shaft seal
Reply #11March 26, 2005, 10:22:52 pm
dieselweasel
  • 312
sold out
« Reply #11 on: March 26, 2005, 10:22:52 pm »
PM sent.  These look fairly easy so swap in...just need a vice and a wrench, right?
Reply #12March 27, 2005, 07:03:53 am
Patrick
  • 1034
sold out
« Reply #12 on: March 27, 2005, 07:03:53 am »
Pretty much, but you still need to test to see if the springs need to be shimmed to get the pressures the same across all four injectors.
Reply #13March 27, 2005, 09:03:10 am
Smog
  • 160
sold out
« Reply #13 on: March 27, 2005, 09:03:10 am »
Quote from: "Patrick"
The nozzles only will do a part of the job but for max results, you need to have them pop tested for opening pressures.
If you can find a set of spare injectors, you can send them to me and for 10$/injector, I will adjust the pressures and install your new nozzles.
IDI Pump shaft seal
Reply #14March 27, 2005, 02:09:45 pm
dieselweasel
  • 312
sold out
« Reply #14 on: March 27, 2005, 02:09:45 pm »
Ok thanks guys...that makes sense.  I have access to a Cat nozzle pop tester...just can't think of what to use to adapt the line to the VW fitting size.  Also I'd need to buy spare injectors and shims.  I think I might just buy reman injectors.  Thanks though.
Fixmyvw.com
