Author Topic: sold out  (Read 70651 times)
Reply #45December 22, 2005, 06:30:49 pm
vwmike
  • 1158
sold out
« Reply #45 on: December 22, 2005, 06:30:49 pm »
10 psi eh? It is damn near impossible to set an injector within 10 psi using a conventional pop tester and the commonly available shims. Spec is 130 to 138 bar (1849 to 1963 psi) for NA or 155 to 163 bar (2248 to 2364 psi) for TD's. A difference of .05mm in shim thickness will cause a pressure change of approximately 5 bar (71 psi).
Reply #46December 23, 2005, 04:54:39 am
Smog
  • 160
sold out
« Reply #46 on: December 23, 2005, 04:54:39 am »
Quote from: "vwmike"
something about using higher pressure injectors in an older diesel ;
sometimes, a badly worn fuel pump will not be able to built the pressure required to open the newly rebuilt injectors; so If I'm asked to bump up the pop-pressure by another 20 bar, the fuel pump MAY NOT be able to work with them unless it got another pump head (like a 10mm or a 11mm from a TDI)
www.VEG-Injection-Service.com
1.6GTD nozzles (RA/SB )
1.9TD nozzles (AAZ )
0.205mm or 0.216mm TDI nozzles
TDI injection pump seal kit
IDI Pump shaft seal
Reply #47January 19, 2006, 06:52:20 am
DubAllStar
  • 9
sold out
« Reply #47 on: January 19, 2006, 06:52:20 am »
Interested in a set of AAZ injectors if you've got any left. If you could advise me as to what's required to install them, and how to pay you, we'll be in business very shortly ;)
Reply #48January 19, 2006, 06:54:47 am
Smog
  • 160
sold out
« Reply #48 on: January 19, 2006, 06:54:47 am »
Quote from: "DubAllStar"
paypal is fine, what is required to install them is a torque limiting wrench.
COD is available for Canadians
IDI Pump shaft seal
Reply #49January 26, 2006, 05:38:52 am
Jeff@TheQuadShop
  • 42
sold out
« Reply #49 on: January 26, 2006, 05:38:52 am »
Ok, i need new nozzles for my 1.9 AAZ. Am I better off getting the AAZ nozzles or going with the GTD ones?
Reply #50January 26, 2006, 05:42:19 am
Smog
  • 160
sold out
« Reply #50 on: January 26, 2006, 05:42:19 am »
Quote from: "Jeff@TheQuadShop"
the GTD may flow a bit better but new nozzles (AAZ or GTD) will give a significant improvement over the stock worn nozzles.
IDI Pump shaft seal
Reply #51January 26, 2006, 10:09:31 am
Jeff@TheQuadShop
  • 42
sold out
« Reply #51 on: January 26, 2006, 10:09:31 am »
Ok, I'll take the GTD's. How do you take payment and what is the total in US funds? I'll take the fast shipping option.
Reply #52January 26, 2006, 10:24:58 am
Smog
  • 160
sold out
« Reply #52 on: January 26, 2006, 10:24:58 am »
85$ + 10$ for a 7 to 10 days shipping
or
give me your postal/ZIP code for a UPS quote
IDI Pump shaft seal
Reply #53January 26, 2006, 03:12:51 pm
Jeff@TheQuadShop
  • 42
sold out
« Reply #53 on: January 26, 2006, 03:12:51 pm »
Ok, so $95can. How do you take payment?
Reply #54January 27, 2006, 03:53:31 am
Smog
  • 160
sold out
« Reply #54 on: January 27, 2006, 03:53:31 am »
paypal at [email protected]
thank you
IDI Pump shaft seal
Reply #55January 29, 2006, 03:11:35 pm
jesse7
  • 3
sold out
« Reply #55 on: January 29, 2006, 03:11:35 pm »
are the TDI nozzles powerplus, sprint or something else?
and is it $160 for a set?
Reply #56January 29, 2006, 04:08:52 pm
Smog
  • 160
sold out
« Reply #56 on: January 29, 2006, 04:08:52 pm »
Quote from: "jesse7"
The TDI nozzles are OEM replacement for the TDI 110hp as the Sprint nozzles are.
and the price is 160$ shipping included for the 0.205mm or the 0.216mm
thank you
IDI Pump shaft seal
Reply #57January 29, 2006, 05:15:43 pm
Jeff@TheQuadShop
  • 42
sold out
« Reply #57 on: January 29, 2006, 05:15:43 pm »
Payment sent.
Reply #58January 29, 2006, 10:43:39 pm
ancient
Re: TDI, 1.9TD (AAZ) and 1.6GTD (RA/SB) nozzles for sale
« Reply #58 on: January 29, 2006, 10:43:39 pm »
Got more GTD nozzles in stock?  I will need one set,  let me know how much total is including shipping.  Thanks.
Quote from: "Smog"
I got 10 sets of 1.6GTD nozzles (RA/SB engines )
and
25 sets of 1.9TD nozzles (AAZ engines)
85$can each set
add 10$ for fast shipping anywhere
I also carry the 0.205mm and 0.216mm nozzles for the TDI at 160$can
Reply #59January 30, 2006, 04:44:48 am
Smog
  • 160
« Reply #59 on: January 30, 2006, 04:44:48 am »
Quote from: "ancient"
Quote from: "Smog"
and
85$can each set
I have a lot of them and you quoted the answer to you question  :lol:
IDI Pump shaft seal
