Author Topic: sold out  (Read 70620 times)
Reply #15March 28, 2005, 04:23:44 am
Smog
  • 160
sold out
« Reply #15 on: March 28, 2005, 04:23:44 am »
Quote from: "dieselweasel"
I think I might just buy reman injectors.  Thanks though.
please tell us the final price for remanufactures injectors. I got a quote at 75$ each injector + tx (300$ + tx / set)
www.VEG-Injection-Service.com
1.6GTD nozzles (RA/SB )
1.9TD nozzles (AAZ )
0.205mm or 0.216mm TDI nozzles
TDI injection pump seal kit
IDI Pump shaft seal
Reply #16March 28, 2005, 06:06:58 am
QuickTD
  • 1156
sold out
« Reply #16 on: March 28, 2005, 06:06:58 am »
I was quoted $120 each for reman 1.9TD two spring injectors by several bosch fuel injection shops. Not what I would call a bargain.
 I'm real happy with my "Smog" GTD/1.9TD hybrid injectors. I retarded the timing a bit and the noise quieted down somewhat. Didn't hurt the power much, it'll still fry the clutch... :D
Reply #17April 04, 2005, 08:39:25 pm
jackbombay
  • 599
sold out
« Reply #17 on: April 04, 2005, 08:39:25 pm »
Quote from: "Smog"
  This place has them for $36 plus $10 core charge, listed under Audi 2.0L TD, same injector right?
Reply #18April 04, 2005, 09:26:05 pm
QuickTD
  • 1156
sold out
« Reply #18 on: April 04, 2005, 09:26:05 pm »
Nope. The audi 2.0TD is a 5cyl that uses 1.6TD components, including injectors.
Real 1.9TD two spring injectors are spendy. I have researched this at length, you cannot get them from the aftermarket...
Reply #19April 06, 2005, 01:21:41 pm
commuter boy
  • 277
Nozzle help!
« Reply #19 on: April 06, 2005, 01:21:41 pm »
I've got an early 1993 Passat 1.9 TD,  the one with the "ecodiesel" fuel
pump with no aneroid.
My problem is, the injectors are different as well, with a different nozzle
#.  The tech who took them apart today said the nozzle was #0434250 159,
and that the injector was a single stage model.
Which nozzle would be appropriate to purchase here?
Reply #20April 06, 2005, 03:18:21 pm
Smog
  • 160
Re: Nozzle help!
« Reply #20 on: April 06, 2005, 03:18:21 pm »
Quote from: "commuter boy"
the AAZ (1.9td) nozzles will do the trick; they can go on single stage injectors also
IDI Pump shaft seal
Reply #21April 07, 2005, 09:56:21 am
fspGTD
  • 1529
sold out
« Reply #21 on: April 07, 2005, 09:56:21 am »
Difference between a 1-spring and a 2-spring injector:
Jake Russell
Reply #22April 08, 2005, 12:17:48 pm
commuter boy
  • 277
sold out
« Reply #22 on: April 08, 2005, 12:17:48 pm »
Then the early 1993 Passat 1.9 AAZ TD's have not only the fuel pump less
the aneroid, but also the single stage injectors, with a weird nozzle inside.
I knew there's a reason it seems sluggish, and gets relatively poor mileage.
Anyone have a 1.9 pump with aneroid they'd like to unload?
I'll be installing the regular 1.9 AAZ dual stage nozzles in the single stage injectors
on the car next week and we'll see how that turns out.
Reply #23April 08, 2005, 02:59:51 pm
Smog
  • 160
sold out
« Reply #23 on: April 08, 2005, 02:59:51 pm »
you can keep the single stage injectors with a real 1.9td pump; no problem with that setup. I think you can swap a 1.6td pump top to your pump but I'm not sure.
IDI Pump shaft seal
Reply #24April 15, 2005, 06:36:28 pm
temp-autobahn
  • 3
sold out
« Reply #24 on: April 15, 2005, 06:36:28 pm »
thanks smog, they arrived in pristine condition. hope they don't sit too long before our dirty NA diesel starts flowing through them
Reply #25April 15, 2005, 09:07:51 pm
dirtytom
  • 46
sold out
« Reply #25 on: April 15, 2005, 09:07:51 pm »
I'm trying to build a 1.6l td to gtd uero spec . I would be happy with realiable 90 hp and am going to put an intercooler on it . I was wundering if the 1.6l 2stage gtd will help and if anyone has sugestions to reach that 90hp with good mpg and reliability feel free to email me at [email protected]
It is sad when you smell smoke while driving and you think" some poor SOB must have an engine fire. Oh well sucks to be them" only to notice smoke billowing out of your car and be over heard saying "not again".
Reply #26April 23, 2005, 10:23:24 am
commuter boy
  • 277
sold out
« Reply #26 on: April 23, 2005, 10:23:24 am »
Got the nozzles installed and the injector's rebuilt by Jim's Fuel Injection in
Vancouver.  Nice work, cheap ($80 for all four), and fast turnaround.
Installed in the car, it runs much, much better.  Smoother, slightly more power.
Looks like the regular 1.9 nozzles are a good fit for the Passat Eco-diesel.
Thanks!
Reply #27May 10, 2005, 03:52:55 pm
dirtytom
  • 46
sold out
« Reply #27 on: May 10, 2005, 03:52:55 pm »
I would like to buy a set of 1.6l gtd ingectors from you. How much would they run. And when would you like me to pay for them.
Reply #28May 11, 2005, 05:52:28 am
Smog
  • 160
sold out
« Reply #28 on: May 11, 2005, 05:52:28 am »
Quote from: "dirtytom"
I only sell the GTD nozzles and you will have to ask your local diesel specialist to install them and pop-test your own injectors.
for you it's 85$us shipping included; and I ask for paypal
IDI Pump shaft seal
Reply #29May 11, 2005, 10:14:56 am
103wgold
sold out
« Reply #29 on: May 11, 2005, 10:14:56 am »
Are AAZ nozzles same as AHU?  I need an diesel injection pump or kit for the AHU also...Thanks, Bill
