Author Topic: sold out  (Read 70606 times)
Reply #30May 11, 2005, 10:18:28 am
Smog
  • 160
sold out
« Reply #30 on: May 11, 2005, 10:18:28 am »
Quote from: "103wgold"
Are AAZ nozzles same as AHU?  I need an diesel injection pump or kit for the AHU also...Thanks, Bill
no the AHU nozzles are the 0.205mm or 0.216mm
(AHU is a TDI engine while AAZ is a TD)
www.VEG-Injection-Service.com
1.6GTD nozzles (RA/SB )
1.9TD nozzles (AAZ )
0.205mm or 0.216mm TDI nozzles
TDI injection pump seal kit
IDI Pump shaft seal
Reply #31May 28, 2005, 08:30:51 am
Smog
  • 160
Re: TDI, 1.9TD (AAZ) and 1.6GTD (RA/SB) nozzles for sale
« Reply #31 on: May 28, 2005, 08:30:51 am »
Quote from: "Smog"
I got 10 sets of 1.6GTD nozzles (RA/SB engines )
and
25 sets of 1.9TD nozzles (AAZ engines)
85$can each set
add 10$ for fast shipping anywhere
I also carry the 0.205mm and 0.216mm nozzles for the TDI at 160$can
I just got a load of new 1.6GTD nozzles; perfect fit for your 1.6 or 1.9td
IDI Pump shaft seal
Reply #32July 08, 2005, 07:54:09 am
Smog
  • 160
« Reply #32 on: July 08, 2005, 07:54:09 am »
ttt
[/quote]
I just got a load of new 1.6GTD nozzles; perfect fit for your 1.6 or 1.9td[/quote]
IDI Pump shaft seal
Reply #33July 08, 2005, 08:32:45 am
vwautotech
  • 13
sold out
« Reply #33 on: July 08, 2005, 08:32:45 am »
email [email protected] or contact 434 996 7643, I have a 1.6 eco diesel, and  I need a injection pump and some nozzles, these are for rebuilding the injectors?
  thanks
Reply #34July 08, 2005, 09:04:20 am
Smog
  • 160
sold out
« Reply #34 on: July 08, 2005, 09:04:20 am »
Quote from: "vwautotech"
exactly
IDI Pump shaft seal
Reply #35July 08, 2005, 09:21:16 am
watsongs
  • 135
sold out
« Reply #35 on: July 08, 2005, 09:21:16 am »
Any of these work for a 1.5?  Do the nozzles come with the, I don't know what you want to call them, end caps?  Mine have cuppung around where the nozzle needle exits.  Thanks -
Greg
Greg Watson
'79 Rabbit, 1.5 liters of fun...
If they can get you to ask the wrong questions, they don't have to worry about the answers...
Reply #36July 08, 2005, 09:26:19 am
Smog
  • 160
sold out
« Reply #36 on: July 08, 2005, 09:26:19 am »
Quote from: "watsongs"
Greg
they will fit but the heatshield is not included (lost cost item from your dealer)
IDI Pump shaft seal
Reply #37August 24, 2005, 10:34:23 am
Jeff@TheQuadShop
  • 42
sold out
« Reply #37 on: August 24, 2005, 10:34:23 am »
Do you have any of the 1.9's left?
Reply #38August 24, 2005, 10:36:33 am
Smog
  • 160
sold out
« Reply #38 on: August 24, 2005, 10:36:33 am »
Quote from: "Jeff@TheQuadShop"
about 20 sets  :D
IDI Pump shaft seal
Reply #39August 24, 2005, 01:56:27 pm
RabbitGTDguy
  • 1274
sold out
« Reply #39 on: August 24, 2005, 01:56:27 pm »
SMOG ...was going to buy GTD nozzles from you....but sold the motor! Sending the buyer your way! Gave him your info, etc... Thanks again!
Joe
1972 VW Westfalia
Reply #40August 24, 2005, 03:36:24 pm
Smog
  • 160
sold out
« Reply #40 on: August 24, 2005, 03:36:24 pm »
Quote from: "RabbitGTDguy"
Joe
thanks
IDI Pump shaft seal
Reply #41August 25, 2005, 05:49:01 am
addautomotive
sold out
« Reply #41 on: August 25, 2005, 05:49:01 am »
Smog,
Looks like my injectors are leaky. I'm interested in a set of your 1.9 GTD nozzles but have a couple questions...
1) You mentioned earlier in this thread that you will "pop test" injectors if you are sent cores. I have a set, so how much would that cost? My spare set is pretty new, so should I keep the stock nozzles or do you prefer to recieve them complete?
2) Any compatibility issues with vegetable oil? I run WVO about 85% of the time, but am very careful about filtration & heat. Will these nozzles perform differently with vegoil for fuel?
Reply #42August 25, 2005, 05:55:25 am
Smog
  • 160
sold out
« Reply #42 on: August 25, 2005, 05:55:25 am »
Quote from: "addautomotive"
Smog,
125$can + shipping and I always send back the used original nozzles with the recalibrated injectors.
no trouble with veggie oil (myself I never had any trouble with veggie oil)
IDI Pump shaft seal
Reply #43August 25, 2005, 06:04:58 am
addautomotive
sold out
« Reply #43 on: August 25, 2005, 06:04:58 am »
SOLD!!! PM Sent!
Reply #44December 22, 2005, 06:24:43 pm
Josh
  • 54
Veg oil (WVO/SVO) pop pressure higher
« Reply #44 on: December 22, 2005, 06:24:43 pm »
For anybody reading this  thread that's interested in WVO/SVO injector mods, you'd ideally want to set your injectors to a higher pop pressure on a VW vehicle.
  Part of a good running WVO/SVO conversion is having hot oil, so assuming you're set up with a good system custom built for your application (you might not be!  There's a lot of hacks out there, I'm afraid!), and your fuel oil is very hot and very thin as it reaches the injection pump, it's viscosity isn't going to be dead on.  It will be a bit thicker; not so thick that it's too difficult for the integrated lift-pump in the vw/bosch inj pump to work, but just a bit thicker that it can cause rough idling problems.  Read the boards about vw SVO/WVO stuff; lots of people have this issue when they rush out and do stuff without thinking and testing.  Set the injectors to 10 psi higher than spec for a TD or TDI engine; maybe 12 for an NA.
  Any stock nozzle will be fine, and any used upgrade nozzle recommended for performance increase by folks using straight diesel should also work.
  Hope this helps!
   -Josh
Quote from: "Smog"
Smog,
'84 Quantum sedan (oops, not '83!)
'83 Quantum wagon(ditto, not '82)
'82 Westfalia
'79 Rabbit
Mmmm.  Diesely.
