Author Topic: 1.6 Help needed (Rusted engine)  (Read 11244 times)
July 31, 2007, 06:46:25 pm
patracy
  • 142
« on: July 31, 2007, 06:46:25 pm »
I've got a 1.6 that I'm trying to rebuild for my project.  However it appears that water was in the engine for a while, enough to rust the cyls. pretty good.  I've had them soaking in oil for the past two days.  But I don't think I'll get it good enough to be able to turn by hand again.  (Lots of scales from rust)
Looking from the bottom of the engine, what bits of the cyl walls I can see don't appear to be rusted.  So my question is, can I drop the crank out and drive the pistons down and out the bottom of the block?
Reply #1July 31, 2007, 08:06:13 pm
Barry W
« Reply #1 on: July 31, 2007, 08:06:13 pm »
The rods and pistons have to come out from the top of the motor. They can't come out the bottom.
Reply #2July 31, 2007, 08:46:53 pm
« Reply #2 on: July 31, 2007, 08:46:53 pm »
can't the pistons come out the bottom with crank removed?  the only thing i can see getting in the way would be the piston oil squirters... and those are only a turn of a wrench away from removing...
Reply #3July 31, 2007, 09:49:00 pm
Barry W
« Reply #3 on: July 31, 2007, 09:49:00 pm »
I'm lookin at my engine pics and I just can't quite see it. It just might be possible, although I've always got em out from the top of the motor.
Reply #4August 01, 2007, 02:47:23 am
patracy
  • 142
« Reply #4 on: August 01, 2007, 02:47:23 am »
Quote from: "jtanguay"
Older 1.6.  No squirters.
Reply #5August 01, 2007, 06:11:46 am
saurkraut
  • 904
« Reply #5 on: August 01, 2007, 06:11:46 am »
Best of my recolection, it has nothing to do with the oil nozzles.  The main bearing bosses are in the way.  the pistons have to go out the top.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #6August 01, 2007, 06:49:22 am
patracy
  • 142
« Reply #6 on: August 01, 2007, 06:49:22 am »
Quote from: "saurkraut"
The main bearing bosses were what I was worried about.  I thought perhaps they might drop out since the piston skirts have releafs in them for clearance.  I guess I'll let it soak for another day or two.  Drop the crank, try to knock the pistons down in the holes a little more, then hone out the rust to have a "clear" path to go out the top.
...hopefully.
I'm betting I'll have to have the block bored and replace the pistons.  I see autozone has a kit for it.  Is there anywhere that has a better price?
(I hoped the engine only had some light rust causing it to freeze.  I hoped to get by with just a re-ring)
Reply #7August 01, 2007, 08:09:21 am
bevboyy
  • 200
« Reply #7 on: August 01, 2007, 08:09:21 am »
What oil are you using? I usually use vast amounts of liquid wrench when I unstick my project motorcycle engines...
1987 Jetta Mk2 - daily driver, MZ 1.8 goodness. TJ auto trans..
Gone but not forgotten:
1985 Mercedes 300d Turbo
1987 Olds Delta 88 Royal Brougham
1992 Mercedes 190e 2.3
1984 Mercedes 190e
1983 Quantum TD
1992 Jetta TD
1983 BMW 533i
1982 BMW 320iS
1979 Mercedes 300D (non turbo)
1977 BMW
Reply #8August 01, 2007, 08:13:27 am
patracy
  • 142
« Reply #8 on: August 01, 2007, 08:13:27 am »
Liquid wrench, an entire can among all cyl.
Reply #9August 01, 2007, 09:45:59 am
bevboyy
  • 200
« Reply #9 on: August 01, 2007, 09:45:59 am »
Give that stuff some time. I usually let it sit for a week or so. Once it is all seeped through, use a propane torch and heat up the top of the piston, especially the area where the rings are contacting the cylinder wall.  Then use a wood dowel and tap the pistons out from the bottom....
1984 Mercedes 190e
1983 Quantum TD
1992 Jetta TD
1983 BMW 533i
1982 BMW 320iS
1977 BMW
Reply #10August 01, 2007, 03:49:47 pm
Black Smokin' Diesel
  • 656
« Reply #10 on: August 01, 2007, 03:49:47 pm »
Yep, it's physically impossible to remove the pistons from the bottom of the block.
Reply #11August 01, 2007, 04:19:21 pm
foxracer1
  • 991
« Reply #11 on: August 01, 2007, 04:19:21 pm »
PB blaster is alot better. imho
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #12August 01, 2007, 04:44:05 pm
bevboyy
  • 200
« Reply #12 on: August 01, 2007, 04:44:05 pm »
PB blaster is also good stuff. You have to break the seal the rings made with the cylinder wall..it can be done.
1984 Mercedes 190e
1983 Quantum TD
1992 Jetta TD
1983 BMW 533i
1982 BMW 320iS
1977 BMW
Reply #13August 01, 2007, 07:23:01 pm
patracy
  • 142
« Reply #13 on: August 01, 2007, 07:23:01 pm »
I should have taken pics before I started to soak them.  They're bad enough where it felt like sandpaper from the scales.
Reply #14August 01, 2007, 07:30:22 pm
« Reply #14 on: August 01, 2007, 07:30:22 pm »
Perhaps you can (eventually) push the pistons way down and then get into each cylinder with a deglazing hone and hone away enough of the rust so that the piston can come out the top.. you're probably looking at re-boring anyway ??
In fact, if you're re-boring anyway you're into it for new pistons... whack...detonation due to a hammer !!
