Author Topic: Sqeak while turning in front end  (Read 4494 times)
July 28, 2007, 04:47:48 pm
coke
  • 254
« on: July 28, 2007, 04:47:48 pm »
Just got done replacing the subframe in my 91 Jetta. Everything went together well, and all front end parts are tight.
When turning the wheel it sounds like something rubbing or squeaking, and it definitely sounds like rubber against metal or rubber against rubber. Anyone experienced this, or any ideas?
Thanks.
Reply #1July 28, 2007, 06:17:36 pm
« Reply #1 on: July 28, 2007, 06:17:36 pm »
depending on what the squeak is, i would say maybe brakes?
Reply #2July 28, 2007, 07:22:09 pm
« Reply #2 on: July 28, 2007, 07:22:09 pm »
sway bar?
hard cornering or normal?
Reply #3July 28, 2007, 08:15:32 pm
coke
  • 254
« Reply #3 on: July 28, 2007, 08:15:32 pm »
Nope, its not the sway bar, and it doesn't matter cornering or not. When the wheel is turning at all, the p/s has a weird rubbery noise coming out of it.
I traced the noise down to the tie rod, inner. When holding the inner rod and moving the wheel I can feel something consistent with the noise. Im thinking it may be something underneath the boot on the rack end, but I was hoping someone else might be able to shed some more light before I go digging into it.
Reply #4July 29, 2007, 04:16:45 am
« Reply #4 on: July 29, 2007, 04:16:45 am »
my car seems to be developing the same sort of noise, but it is intermittant and only when hard cornering (90% of the time  :lol:)
Reply #5August 01, 2007, 05:51:01 pm
bigblockchev
  • 271
noises
« Reply #5 on: August 01, 2007, 05:51:01 pm »
If you can, grease the ball joints and see if it goes away. If you don't have grease nipples you can use one of the needle fittings for your grease gun & stick it through the boot. It's a cheap fix if it works and if it doesn't it wont hurt anything. Cheers Dan
it's always something simple
87 Mercedes 190D 2.5 Turbo
2000 Jetta TDI
76 Onan  MDJF 15Kw genset
