Author Topic: n/a head - turbo head differences - comparisons..  (Read 5001 times)
June 12, 2007, 09:49:46 am
bevboyy
  • 200
« on: June 12, 2007, 09:49:46 am »
Besides the valves being different, what else is different for a n/a head and a turbo head. Can I swap valves and use a n/a head on my turbo block? I just picked up a 1.6 that has only 100k on the factory rebuilt long block assembly...
1987 Jetta Mk2 - daily driver, MZ 1.8 goodness. TJ auto trans..
Gone but not forgotten:
1985 Mercedes 300d Turbo
1987 Olds Delta 88 Royal Brougham
1992 Mercedes 190e 2.3
1984 Mercedes 190e
1983 Quantum TD
1992 Jetta TD
1983 BMW 533i
1982 BMW 320iS
1979 Mercedes 300D (non turbo)
1977 BMW
Reply #1June 12, 2007, 10:58:27 am
Re: n/a head - turbo head differences - comparisons..
« Reply #1 on: June 12, 2007, 10:58:27 am »
Quote from: bevboyy
Besides the valves being different, what else is different for a n/a head and a turbo head. Can I swap valves and use a n/a head on my turbo block? I just picked up a l.6 that has only l00k on the factory rebuilt long block assembly...
I'm told the material the head is made out of it differant material not just the valve's and valve seats.
Depends on how hard you are gonna run it.
Reply #2June 12, 2007, 11:22:37 am
« Reply #2 on: June 12, 2007, 11:22:37 am »
supposedly the hydraulic n/a heads are basically turbo (don't know the years that have it... but etka is showing the same part number.)
the valves may not be turbo though...
Reply #3June 12, 2007, 01:58:25 pm
bevboyy
  • 200
« Reply #3 on: June 12, 2007, 01:58:25 pm »
I'd be looking at running 15-18psi. Nothing huge. It's a solid lifter head. I think I can use it, just install the proper valve seats and valves.
1984 Mercedes 190e
1983 Quantum TD
1992 Jetta TD
1983 BMW 533i
1982 BMW 320iS
1977 BMW
Reply #4June 12, 2007, 02:21:20 pm
bevboyy
  • 200
« Reply #4 on: June 12, 2007, 02:21:20 pm »
Well won't wonders ever cease? I checked three part supplier databases.
Beck/Arnley and TRW show the same part numbers for intake and exhaust valves and seats for both CY and CR and JK engines.
The new engine I have was from a '81 Bunny, Engine was a longblock from VW Canada. Since it's a reman, it could be a JK as it has the 12mm head bolts.
My TD is a CY, so this may just work fine as is....
Opinions???
1984 Mercedes 190e
1983 Quantum TD
1992 Jetta TD
1983 BMW 533i
1982 BMW 320iS
1977 BMW
Reply #5June 12, 2007, 02:25:35 pm
« Reply #5 on: June 12, 2007, 02:25:35 pm »
They probably only make the TD valves now as they stopped making NA engines. I'd order new valves if I were you then.
Reply #6June 12, 2007, 02:41:43 pm
« Reply #6 on: June 12, 2007, 02:41:43 pm »
my dad has a na head on a td block, he put a td valves in it though, but he has no issues his car is 100% stock.
Reply #7June 12, 2007, 02:45:21 pm
bevboyy
  • 200
« Reply #7 on: June 12, 2007, 02:45:21 pm »
Yes, but as far as I can see, both the CY Turbo and the CR/JK N/a heads share the same part numbers. Now maybe they are substituting turbo valves in lieu of n/a valves. This would remain to be seen. Keep also in mind that they spec different part numbers for hydraulic heads... I have another head, I'll pull the valves out of that and compare. I have hunch I could run the head as is...
1984 Mercedes 190e
1983 Quantum TD
1992 Jetta TD
1983 BMW 533i
1982 BMW 320iS
1977 BMW
Reply #8June 13, 2007, 09:42:21 am
bevboyy
  • 200
« Reply #8 on: June 13, 2007, 09:42:21 am »
Hunches are 100% spot on. Found out new long block was installed in '88 and the part numbers are identical - E designation - Stamped '84 so the head is indeed a TD head. Time to pull the pan to check if the block is also a TD...
1984 Mercedes 190e
1983 Quantum TD
1992 Jetta TD
1983 BMW 533i
1982 BMW 320iS
1977 BMW
Reply #9June 13, 2007, 01:06:18 pm
Pondering question
« Reply #9 on: June 13, 2007, 01:06:18 pm »
Heres something else I have been wondering about.
Can we use the hydro lifters in the solid head?
Maybe drill a oil supply hole for the lifters?
This would eliminate the need to plug the second return hole when using a hydro head on a solid block.
I have 2 cracked heads now, one from the precup to the intake valve (solid head) and the other has a cracked cam tower where the stud screws in (hydro head).
I still have one solid head here but really want a hydro head. Would have just bought one from Burn_your_money but I guess he is MIA.
Reply #10June 13, 2007, 01:49:10 pm
bevboyy
  • 200
« Reply #10 on: June 13, 2007, 01:49:10 pm »
It would cost more to do that than to get another head. NotoriousVr on the vortex has what you are looking for. It just needs one of the injector bosses to be welded, not a big thing, otherwise it's in good shape. I checked it out when I was over at his place picking up my cluster..
1984 Mercedes 190e
1983 Quantum TD
1992 Jetta TD
1983 BMW 533i
1982 BMW 320iS
1977 BMW
Reply #11June 13, 2007, 04:56:14 pm
tylernt
  • 344
Re: Pondering question
« Reply #11 on: June 13, 2007, 04:56:14 pm »
Quote from: "zukgod1"
I asked that same question. Somebody said the solid and hydraulic lifters are different diameters and/or different heights.
Reply #12June 14, 2007, 12:14:43 am
BellCityDubber
  • 251
« Reply #12 on: June 14, 2007, 12:14:43 am »
Quote from: "bevboyy"
You mean Itchyg60....
I've been interested in that head for a while now. but I also have a head that is from an 88 I believe, but I guess from what you're saying is that the later model heads have TD Valves and should run in a TD... correct?
if that's the case, I'll take this spare head out for some headwork :)
Reply #13June 14, 2007, 07:23:21 am
bevboyy
  • 200
« Reply #13 on: June 14, 2007, 07:23:21 am »
Yes, all heads it seems after 86 are the same. So yeah, clean the head surface with a good strong degreaser (if you're cheap like me, use Easy Off oven cleaner..) and inspect your head for prechamber cracks, if all good, then drop it off at a machinist and get it squared. 8)
1984 Mercedes 190e
1983 Quantum TD
1992 Jetta TD
1983 BMW 533i
1982 BMW 320iS
1977 BMW
Reply #14June 14, 2007, 09:18:21 am
« Reply #14 on: June 14, 2007, 09:18:21 am »
LOL I don't go on the computer for 36 hours and everyone assumes I just disappeared.
Quote from: "BellCityDubber"
That's my old head... the first TD engine I ever bought. I bought it off RPM motors in Bolton IIRC
