Pretty much every stock diesel on the market will do that (Especially the Dodge/GM/Ford pickups in the states), it's considered normal and not really harmful.
when i pull to full boost, and i release on a high rpm, my turbo makes dumpvalve sound, is that surge also? Do i need to use a dieseldumpvalve?
now the vnt is even not fulle adjusted, the vanes dont close much when offboost.
Greetz, Benjamin
No, that's normal when you are using high boost. Surge is a chattering sound and you can hear it very clearly at first and then it fades away. It's like
TSAT-
tsat-
TSAT-
tsat-
TSAT-
tsat
If it isn't harmful then why would manufacturers bother spending the time and money to design surge protection into turbos? It puts a lot of stress on the turbo.
Greetz, Benjamin
No, that's normal when you are using high boost. Surge is a chattering sound and you can hear it very clearly at first and then it fades away. It's like TSAT-tsat-TSAT-tsat-TSAT-tsat
to me that is the mostest coolest sound,lol
i make mine do it on purpose,sorta
wind it out in a gear,lots of boost....then push in the clutch,and shift grandma slow,,you get the chuffin sound
it sounds like rapid flatuation,,lol
:lol: :lol:
:shock: :shock:
surge, not good in any way, shape, or form.
It's like spinning a bike wheel up and then shoving a stick in the spokes.
and hillfolk, that'd explain why your turbos blow so fast :wink:
:shock: :shock:
it was an answer to my quistion, we'r not talking about surge
Greetz, Benjamin
oh ok, didn't read back any, my fault.
:shock: :shock:
one of the garretts blew a the exhaust wheel right out of the dp at the drags at the 1000 foot mark
one of the kkk's let that lame thrust bearing go at hi revs+pumped about 1 qt of oil in the intake
so no that doesnt explain why im blowing turbos
maybe its because i let them go full boost(40+psi) ,and im seeing 1500degree exhaust temps
the turbine wheels are literaly melting off ,or getting fatigued
