Author Topic: 1.9 head on a 1.6 mech. block  (Read 10772 times)
December 02, 2006, 07:22:41 am
saurkraut
  • 904
« on: December 02, 2006, 07:22:41 am »
Just scored a new 1.9 IDI head.  I intend to put in on my 1.6 mech. block.
Anyone have a good solution for the extra oil return/coolant passage issue?
Also, as long as its brand new, I think I'll do the ceramic coating in the prechambers, head, and exhaust ports.  Any body had this done befor. and who did it?
Its going to be a winter project while my '79 hibernates.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #1December 02, 2006, 07:38:48 am
« Reply #1 on: December 02, 2006, 07:38:48 am »
just plug the extra hole and then it's basically a bolt on.  the aftermarket heads are designed to fit both mechanical and hydro engines, although it is a mechanical one, it has like a dummy extra oil drain with no hole in it.  just plug the oil drain then the head is basically bolt on just like a normal solid lifter head,
Reply #2December 02, 2006, 07:39:14 am
« Reply #2 on: December 02, 2006, 07:39:14 am »
also, how does the 1.5td run compared to the 1.6td
Reply #3December 02, 2006, 08:11:57 am
saurkraut
  • 904
« Reply #3 on: December 02, 2006, 08:11:57 am »
The head is a NOS 1.9 head.
The extra oil drain hole is open.  i also want to run the metal HG.  I supose i'll go with BSP threaded plugs unles someone has a better suggestion.
just looking for someone that has done it successfully.
The 1.5 is still in work, its my winter rabbit.  just a month or so behind schedule.  Still collecting the turbo plumbing.  Manifolds and turbo are on.;  Airbox, turbodrain and what IP to use are the remaing issues.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #4December 02, 2006, 09:14:56 am
Audi80
« Reply #4 on: December 02, 2006, 09:14:56 am »
For metal HG, you will have to block the second return hole from gasket also. I used 2mm rubber for it.
Reply #5December 02, 2006, 10:11:25 am
« Reply #5 on: December 02, 2006, 10:11:25 am »
run the 1.5 pump, unless you want an lda, but the 1.5 pump will give me revs than a 1.6 pump, should help give it more ass, they are supposedly a little better.
Reply #6December 02, 2006, 01:04:01 pm
saurkraut
  • 904
« Reply #6 on: December 02, 2006, 01:04:01 pm »
Yup, going to use a 1.5 pump.  I'd like to put the LDA top on the 1.5 pump, but I haven't gotten around to putting the two pumps side by side and see if it possible to swap the tops.
i emailed Giles but haven't heard back yet.  I guess he is really busy now.  If the tops aren't intercangeable, maybe some of the guts are intercangeable.
Probably have to do a rebuild as every used pump I've put on other diesels has leaked eventually.
I'm really interested to see the results.  I even saved a crank and rods from a 1.5 to put in my 1.6 if things work out.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #7December 02, 2006, 04:01:50 pm
935racer
« Reply #7 on: December 02, 2006, 04:01:50 pm »
Maybe I am missing something but you can't mount a hydro head on a mechanical block, what is going to give the lifters pressure?
Reply #8December 02, 2006, 04:11:41 pm
« Reply #8 on: December 02, 2006, 04:11:41 pm »
Quote from: "935racer"
Yeah now that you mention it I seem to recall reading that you can use a mech head on a hydro block but not vise-versa
Reply #9December 02, 2006, 05:20:14 pm
935racer
« Reply #9 on: December 02, 2006, 05:20:14 pm »
I know you can't, unless these reman heads come with mechanical cam followers, which I highly doubt they do, than its just like a factory head. Hydro heads only go on hydro blocks, Mechanical heads will fit on either.
Reply #10December 02, 2006, 07:55:12 pm
« Reply #10 on: December 02, 2006, 07:55:12 pm »
he doesn't have aftermarket... but the aftermarket one i have will go on either.  i've read here several times that you can put a hydro head on a mechanical block but blocking the drain hole
Reply #11December 02, 2006, 08:06:07 pm
935racer
« Reply #11 on: December 02, 2006, 08:06:07 pm »
Quote from: Trev0rbr
How do the lifters get oil pressure and how does it drain back into the block?
Reply #12December 02, 2006, 08:19:39 pm
saurkraut
  • 904
« Reply #12 on: December 02, 2006, 08:19:39 pm »
Its a NOS bare head, guides only. I was planning on running solid lifters. Will they fit in the Hydro head?
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #13December 02, 2006, 08:21:27 pm
« Reply #13 on: December 02, 2006, 08:21:27 pm »
just so you know i am not arguing in any way or anything, but the drain holes are the same right. theres 3 of them 2 in the back and 1 in the front, then a hydro head has an extra one in the front, thats the one you plug right.  and wouldn't they just get oil through the normal passages?
Reply #14December 03, 2006, 05:59:54 am
saurkraut
  • 904
« Reply #14 on: December 03, 2006, 05:59:54 am »
A lot of stuff flying around here.
Finish this statement:
"It is IMPOSSIBLE to put a hydro head on a mechanical block because....."
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
