Author Topic: Glow Plug Fusable Link Alternative ? Help  (Read 2894 times)
October 09, 2006, 08:58:19 am
BioDieselVW
  • 93
« on: October 09, 2006, 08:58:19 am »
I remember reading on here about some one using a breaker switch in place of the thin metal fusable link for the glow plugs. Can this be safely done? What size breaker would be used? amps? Thanks
81 Caddy 1.6 TD
Callaway Intercooler
4in Exhaust Stack
Super Pump !
Reply #1October 09, 2006, 11:16:33 am
veeman
  • 421
« Reply #1 on: October 09, 2006, 11:16:33 am »
I believe the fuse strip on my TD is 50 amps, but I'm not sure if they're all the same from model to model.   I think I paid about a $1 each for the fuses that I got locally...   Are you having issues with that fuse blowing?
81 Caddy TD
98 Audi A4 Quattro V6 TDI
83 VW GTI FSP
86 4ktq
Reply #2October 09, 2006, 11:35:08 am
« Reply #2 on: October 09, 2006, 11:35:08 am »
can you get 12v breakers??? @ 50 amps?
Reply #3October 09, 2006, 12:46:41 pm
zagarus
  • 619
« Reply #3 on: October 09, 2006, 12:46:41 pm »
i sure got one  :D
Reply #4October 09, 2006, 01:14:17 pm
BioDieselVW
  • 93
« Reply #4 on: October 09, 2006, 01:14:17 pm »
today was the first time the fuse wnt bad on me. I was considering alternatives because my VW shop is closed on mondays and i thought it would be cool to be able to just reset it if it happened again.
So is 50 amps what would be used?
81 Caddy 1.6 TD
4in Exhaust Stack
Super Pump !
Reply #5October 09, 2006, 02:42:19 pm
zagarus
  • 619
« Reply #5 on: October 09, 2006, 02:42:19 pm »
yep 50 amp.
Reply #6October 10, 2006, 09:16:19 pm
wyldman
  • 403
« Reply #6 on: October 10, 2006, 09:16:19 pm »
Stereo shops should have HD resetable breakers.I think it's overkill though.it's so easy to change,just carry a spare or two.
A piece of 14-16 ga wire can be used in a pinch.You can even jump it with anything metal,just be prepared if there is a short,it may get hot.
(416)565-7282
Reply #7October 12, 2006, 01:08:35 am
HarryMann
  • 170
« Reply #7 on: October 12, 2006, 01:08:35 am »
.. and if your shop runs out of 50 amp ones, they'll likely have 80 amp ones too to get you out of a spot.  Just like carrying a spare bulb or fusebox fuse with you. Don't stress or twist it when installing and it'll last for years.
