Glow Plug Fusable Link Alternative ? Help
Topic: Glow Plug Fusable Link Alternative ? Help (Read 2893 times)
October 09, 2006, 08:58:19 am
BioDieselVW
October 09, 2006, 08:58:19 am »
I remember reading on here about some one using a breaker switch in place of the thin metal fusable link for the glow plugs. Can this be safely done? What size breaker would be used? amps? Thanks
81 Caddy 1.6 TD
Callaway Intercooler
4in Exhaust Stack
Super Pump !
October 09, 2006, 11:16:33 am
veeman
October 09, 2006, 11:16:33 am »
I believe the fuse strip on my TD is 50 amps, but I'm not sure if they're all the same from model to model. I think I paid about a $1 each for the fuses that I got locally... Are you having issues with that fuse blowing?
81 Caddy TD
98 Audi A4 Quattro V6 TDI
83 VW GTI FSP
86 4ktq
October 09, 2006, 11:35:08 am
October 09, 2006, 11:35:08 am »
can you get 12v breakers??? @ 50 amps?
October 09, 2006, 12:46:41 pm
zagarus
October 09, 2006, 12:46:41 pm »
i sure got one
Project 1.9TD Jetta Coupe Completed. Back in action!
October 09, 2006, 01:14:17 pm
BioDieselVW
October 09, 2006, 01:14:17 pm »
today was the first time the fuse wnt bad on me. I was considering alternatives because my VW shop is closed on mondays and i thought it would be cool to be able to just reset it if it happened again.
So is 50 amps what would be used?
81 Caddy 1.6 TD
4in Exhaust Stack
Super Pump !
October 09, 2006, 02:42:19 pm
zagarus
October 09, 2006, 02:42:19 pm »
yep 50 amp.
October 10, 2006, 09:16:19 pm
wyldman
Authorized Vendor
October 10, 2006, 09:16:19 pm »
Stereo shops should have HD resetable breakers.I think it's overkill though.it's so easy to change,just carry a spare or two.
A piece of 14-16 ga wire can be used in a pinch.You can even jump it with anything metal,just be prepared if there is a short,it may get hot.
Auto Proformance Services - VW Diesel parts and service
(416)565-7282
October 12, 2006, 01:08:35 am
HarryMann
October 12, 2006, 01:08:35 am »
.. and if your shop runs out of 50 amp ones, they'll likely have 80 amp ones too to get you out of a spot. Just like carrying a spare bulb or fusebox fuse with you. Don't stress or twist it when installing and it'll last for years.
