what size banjo's on the KKK turbo?
Topic: what size banjo's on the KKK turbo? (Read 3465 times)
August 15, 2006, 08:31:58 am
regcheeseman
August 15, 2006, 08:31:58 am »
Anyone know what size the banjo fittings are on the KKK's, I want to make up some lines for boost controller/ gauge
August 15, 2006, 06:09:13 pm
zooky
August 15, 2006, 06:09:13 pm »
no idea.
But when I was at the bone yard I noticed that the gasser VW's used some nice braided stainless steel lines that looked like the same banjo...
August 15, 2006, 07:25:33 pm
hillfolk'r
August 15, 2006, 07:25:33 pm »
i wanna say 10mm,but the thread picth,,i dunno
Throttle cables ftw
August 15, 2006, 10:19:42 pm
LeeG
August 15, 2006, 10:19:42 pm »
My spare K24 has 8mm x 1.00 pitch.
Banjo on the compressor housing, straight through pipe type fitting on wastegate. Same thread both ends, wastegate end looks like maybe it should have a washer under for seal, but my spare does not.
'97 Passat TDI
August 21, 2006, 10:13:34 pm
fspGTD
August 21, 2006, 10:13:34 pm »
CIS fuel banjos (like to the cold start fuel injector) fit perfectly.
Jake Russell
Dieselicious
Turbocharger Upgrade/Rebuild Kits
August 21, 2006, 11:14:27 pm
hillfolk'r
August 21, 2006, 11:14:27 pm »
doyou have the stock pipe on the turbo for the wastegate? you just cut it like mine
Throttle cables ftw
