Author Topic: what size banjo's on the KKK turbo?  (Read 3482 times)
August 15, 2006, 08:31:58 am
regcheeseman
  • 714
« on: August 15, 2006, 08:31:58 am »
Anyone know what size the banjo fittings are on the KKK's, I want to make up some lines for boost controller/ gauge
Reply #1August 15, 2006, 06:09:13 pm
zooky
  • 71
« Reply #1 on: August 15, 2006, 06:09:13 pm »
no idea.
But when I was at the bone yard I noticed that the gasser VW's used some nice braided stainless steel lines that looked like the same banjo...
Reply #2August 15, 2006, 07:25:33 pm
hillfolk'r
  • 1532
« Reply #2 on: August 15, 2006, 07:25:33 pm »
i wanna say 10mm,but the thread picth,,i dunno
Throttle cables ftw
Reply #3August 15, 2006, 10:19:42 pm
LeeG
  • 401
« Reply #3 on: August 15, 2006, 10:19:42 pm »
My spare K24 has 8mm x 1.00 pitch.
Banjo on the compressor housing, straight through pipe type fitting on wastegate.  Same thread both ends, wastegate end looks like maybe it should have a washer under for seal, but my spare does not.
'97 Passat TDI
Reply #4August 21, 2006, 10:13:34 pm
fspGTD
  • 1529
    • http://home.comcast.net/~vwgtd
« Reply #4 on: August 21, 2006, 10:13:34 pm »
CIS fuel banjos (like to the cold start fuel injector) fit perfectly. :)
Jake Russell
Dieselicious Turbocharger Upgrade/Rebuild Kits
Reply #5August 21, 2006, 11:14:27 pm
hillfolk'r
  • 1532
« Reply #5 on: August 21, 2006, 11:14:27 pm »
doyou have the stock pipe on the turbo for the wastegate? you just cut it like mine
Throttle cables ftw
