Author Topic: engine start up  (Read 5570 times)
July 30, 2006, 02:37:55 am
Benjamin
  • 485
engine start up
« on: July 30, 2006, 02:37:55 am »
My car wont start  :?
i did a rebuild on my Fiat 1.9TD engine.
I have putted a new head on it.
i also tooked the pump of, an i placed a 11mm plunjer (normal: 9mm). The camplate is from a Fiat (same engineblock, other pistons & head) a TDI-m, the camplate is as deep as the original, but i didnt looked good enough to the angle is the same, at my first view it looked the same!
The pump is tested by Bosch, and i know he turned back the quantityscrew, he said the pump was ok.
my engine was ready to start, i first wanna make oil pressure offcorse to save the bearing from my turbo. (i started on the enginestarter  :(  normaly i start by pulling the car after a other car, but it cant becouse the car is not ready on the outside) so after i got oil pressure, i gived the dieselpump-solonoid the signal, an i tryied to start it, i placed a elektric pump to help the dieselpump. After trying to start, i tooked some gaz (dont know this is the rght word > this is the thing i used http://blogs.citypages.com/blotter/images/blotter%20gas%20112305.jpg ) with this gaz it started, and it start running diesel to (thats what i smelted and saw comming a lot of smoke out the exhaust) but it got no any HP, the engine can run on 800rpm, when puching the pedal once to the floor it revs to 2000rpm, and it comming back slowly (with my pedal to the metal) to 800, if i let my pedal free, the engine stops, when i start with this gaz and the engine run 800, somethimes it just stops. i can not rev more than 2000rpm, after that, the engine stops  :roll:
i was trying yesterday, a whole day  :?   in the morning a had 70°C water.
but offcorse i can not start every 1minit, i wanna save my starter to  :wink:
What can be the problem, i even used a bottle to make shure the engine gets clean diesel. Is there still to much air in the pump? maybe the quantityscrew is pulled to much back. air in the injector lines?
right know i cant try anymore becouse a got a little oil problem wich will be fixed monday ore teusday.
I hope someone can help my start this pump an engine up.
Greetz, Benjamin (i hope my english is not too bad)
Must make +250hp
Reply #1July 30, 2006, 09:57:56 am
engine start up
« Reply #1 on: July 30, 2006, 09:57:56 am »
hmmm might be a timing problem?  Or some adjustments on the pump?
Reply #2July 30, 2006, 12:46:01 pm
Benjamin
  • 485
engine start up
« Reply #2 on: July 30, 2006, 12:46:01 pm »
Quote from: jtanguay
i realy hoped someone could say its airbubles in the pump / injector lines.
i hope its not the camplate? maybe the quantityscrew?
how do you guys start a engine up?
Greetz, Benjamin
Must make +250hp
Reply #3July 30, 2006, 02:55:16 pm
engine start up
« Reply #3 on: July 30, 2006, 02:55:16 pm »
I seem to remember getting similar performance with my pump time 180 off.
Reply #4July 31, 2006, 10:21:11 am
Benjamin
  • 485
engine start up
« Reply #4 on: July 31, 2006, 10:21:11 am »
Quote from: 745 turbogreasel
can it be i installed my camplate 180degrees wrong?
Greetz, Benjamin
Must make +250hp
Reply #5July 31, 2006, 10:51:14 am
engine start up
« Reply #5 on: July 31, 2006, 10:51:14 am »
bubbles in the line will make it miss, but you could still rev it.  If the guy from bosch said the pump was okay, I'd take his word for it.. (for now)  Did he actually test the pump?
Reply #6July 31, 2006, 11:13:13 am
Benjamin
  • 485
engine start up
« Reply #6 on: July 31, 2006, 11:13:13 am »
Yes, i told him i did something with the pump (but i didnt said it was only the camplate + 11mm)
In the area its the "best" Bosch guy, thats what they say here. but exaly they dont know the informations they got on this forum, Giles guys dont exist in Belgium  :P
Greetz, Benjamin
Must make +250hp
Reply #7July 31, 2006, 11:22:02 am
engine start up
« Reply #7 on: July 31, 2006, 11:22:02 am »
I think 'Myna diesel'(Finland) goes beyond anything us poor deprived north americanos can get...unless they only do inline pumps.
180 out, there are so many holes in the pump pulley....and i am easily confused or distracted.
I guess it is also possible to get the pump that far out internaly while you have it apart.
Reply #8August 02, 2006, 09:13:20 am
Benjamin
  • 485
engine start up
« Reply #8 on: August 02, 2006, 09:13:20 am »
i found the problem  :D
There is a screw for the supply from the diesel at the pump, i used a screw for it wich is for the exit of the diesel (wich go back to the tank).
FINALY my engine runs  8)
the screw from the "out" got a constriction.
Tnx for reply's anyway!!!!!!!!
Greetz, Benjamin
Must make +250hp
Reply #9August 16, 2006, 08:59:28 am
Benjamin
  • 485
engine start up
« Reply #9 on: August 16, 2006, 08:59:28 am »
okay, after running a couple minits my engine stoped, again  :x
the engine could rev, but once the rpm go under 1500 the engine stoped.
the engine was very noisy, a sound like you think the valves had to much play but loud! much smoke.
so i thought the camplate was wrong in it, i tried to change it 180, the car was not so noisy, but no power, and much much smoke.
so i heard a click / tick when i let my pump rotate, it didnt sound good and the pump valve on the camplate are very hard, so it wasnt easy to rotate the pump.
it seems to be the camplate is a little bit difrent  :shock:
i used mu stock camplate, the 11mm plunjer in again.
it runs again and its very smooth  8)  :D  8)
I'm very glad, let the bigger turbo come  :D
i gonna drive soft the first 1000km.
Greetz, Benjamin
Must make +250hp
