Author Topic: MK3 GTD  (Read 10862 times)
April 25, 2006, 10:57:30 am
envy
  • 19
MK3 GTD
« on: April 25, 2006, 10:57:30 am »
Hey guys,
Iµ newbe here, and havn't read all forum!
My quastion:
how to make it run faster without risk of broken engine??
Engine code is AAZ!
So? What to do??
How big plnjer I need?
May be I need intercooler?
Other injectors?
I'll be pleased for help!!!  8)
TDI PD ~150HP & 380Nm
Reply #1April 25, 2006, 12:03:52 pm
  • 1156
    • Malone Tuning Ltd.
Re: MK3 GTD
« Reply #1 on: April 25, 2006, 12:03:52 pm »
Welcome to the club. I suggest taking the time to read this forum more thoroughly to learn more about IDI / TD performance. There's plenty of juicy information here!
Definitely get an intercooler. What type of turbo do you have? i.e. T2, K03, K14? If you have a really small turbo like the K03 then upgrading to a K24 or T3 from a MK2 1.6TD (engine code CY, MF, and maybe another) will be more worthwhile. Get a 10mm or 11mm plunger, GTD nozzles, and do a governor mod. There are small details like pump timing advance etc. that you will find in this forum. Your car will be much quicker then.
Here's the thread for you to start reading (cheap mods):
http://vwdiesel.net/phpBB/viewtopic.php?t=579
http://www.tunezilla.com
93 Eurovan AHU TDI
17 BMW 328d wagon - Sold
09 BMW 335d 3.0L
Reply #2April 25, 2006, 12:09:06 pm
envy
  • 19
Re: MK3 GTD
« Reply #2 on: April 25, 2006, 12:09:06 pm »
Thanx Malone ;)
Acctually I havn't looked for turbo type...  :oops: because Guru's in my country Latvia say that this engine is very weaka and broke very fast...  :cry:
But when I found this forum - become very happy!
By the way - our club is http://www.vwmotion.lv! welcome! but I doubt you wiil understand, because it is in Latvian  :P  Latvia is small country in East-Europe ;)
Reply #3April 25, 2006, 12:17:40 pm
  • 1156
Re: MK3 GTD
« Reply #3 on: April 25, 2006, 12:17:40 pm »
Quote from: envy
That reminds me; did you get a crank fix? There's quite a few threads discussing the crank sprocket issue on AAZs.. it's necessary preventative maintenance. Other than that AAZs don't seem easy to break - they can last a long time with care.
93 Eurovan AHU TDI
09 BMW 335d 3.0L
Reply #4April 25, 2006, 12:23:06 pm
HP
  • 225
Re: MK3 GTD
« Reply #4 on: April 25, 2006, 12:23:06 pm »
Quote from: malone
A bit offtopic, but I just had enuff of being the only one here who doesn't know wot is a g*dd*mn plunger!!  :oops:  :evil:  :lol:
Can someone explain that to me?!
10mm, 11mm, 12mm... is that 10mm long, 10mm thick?!  :?  Is that a part from the IP?! What's its functionality?!
I want to know everything  :lol:
Reply #5April 25, 2006, 12:25:11 pm
envy
  • 19
Re: MK3 GTD
« Reply #5 on: April 25, 2006, 12:25:11 pm »
Quote from: malone
could you explain what is crank?? my technical english is pure...
But I havn't done anything yet, except games with fuel pump screw!
Reply #6April 25, 2006, 12:28:55 pm
envy
  • 19
Re: MK3 GTD
« Reply #6 on: April 25, 2006, 12:28:55 pm »
Quote from: HP
Quote from: malone
A bit offtopic, but I just had enuff of being the only one here who doesn't know wot is a g*dd*mn punger!!  :oops:  :evil:  :lol:
it is the device in fuel pump which do the rest of work of fuel pumping to injectors! Sorry for english!
Reply #7April 25, 2006, 12:31:55 pm
envy
  • 19
MK3 GTD
« Reply #7 on: April 25, 2006, 12:31:55 pm »
one more quastion before studying forum!
If i have VW GOLF GTD, don† I have GTD nozles??  :?
Reply #8April 25, 2006, 12:35:05 pm
BlackTieTD
  • 1512
Re: MK3 GTD
« Reply #8 on: April 25, 2006, 12:35:05 pm »
Quote from: envy
the crank is at the bottom of the engine. it is the thick metal shaft that transfers the power from the pistons to the transmission. the pulley on the belt side of the crank is often updated and the crank modified on AAZ motors as preventative maintenance. the TDIs don't have this problem.
Reply #9April 25, 2006, 12:40:38 pm
HP
  • 225
MK3 GTD
« Reply #9 on: April 25, 2006, 12:40:38 pm »
If you still have dificulties to understand, here is a pic of a crankshaft or simply crank:
On this board, when people say GTD nozzles, they mean tha 1.6TD RA/SB nozzles. They don't have these engines neither the actual GTD versions (just "regular" TD's) on North America, so they call them GTD nozzles.
I think that's it.  :)
Reply #10April 25, 2006, 12:41:41 pm
  • 1156
MK3 GTD
« Reply #10 on: April 25, 2006, 12:41:41 pm »
Quote from: envy
My mistake, I assumed that you wanted your car to become "GTD." I did not know MK3 GTDs were made :oops:. Also, MK2 GTDs have intercoolers from the factory.. yet your MK3 does not have one?
The additional fuel requires additional boost & therefore intercooling would seem wise.
You could have GTD injectors.. I wonder if there's a part # for it?
93 Eurovan AHU TDI
09 BMW 335d 3.0L
Reply #11April 25, 2006, 12:44:43 pm
envy
  • 19
MK3 GTD
« Reply #11 on: April 25, 2006, 12:44:43 pm »
I  understood, but thank's for pic ;)
Mk3 GTD was built with GT body and interior, thats all, engine - the same AAZ, without cooler!
Reply #12April 25, 2006, 12:47:25 pm
envy
  • 19
MK3 GTD
« Reply #12 on: April 25, 2006, 12:47:25 pm »
could you give the link to preventative jobs of crank???
Reply #13April 25, 2006, 12:53:21 pm
HP
  • 225
MK3 GTD
« Reply #13 on: April 25, 2006, 12:53:21 pm »
Quote from: malone
Well, that's not entirely true, malone. In fact, mine is a GTD, yet it doesn't have an IC.  :)
I'm aware the GTD's were only sold in Europe, thus, a little confusion of yours. GTD is only the version of the car, as it's commercially available. There are GL TD's, CL TD's, and maybe others. So, the GTD is just the TD in a GTI outfit.
JR and RA/SB (the latter with IC) engines for 1.6TD's, among them, some versions are named as GTD's for having things like alloy wheels and other equipment features similar to the GTI.
Then there is the 1.6TD Katalysator or Eco as you know it in NA. That's has its 1V engine only and relatively little equipment. Not GTD, of course. I realize this is a comon version overthere, but not here in Europe.
As for Mk3's, there's only one 1.9TD: the AAZ. Some are named as GTD's for the same reasons as the Mk2's, and the other's, simply TD's. But the engine is all the same and no IC on Mk3's IDI.
IC = intercooler, for envy  :wink:
Reply #14April 25, 2006, 12:58:45 pm
envy
  • 19
MK3 GTD
« Reply #14 on: April 25, 2006, 12:58:45 pm »
perfect HP ;)
and I know what's IC  :P
