Author Topic: New 1.6TD Pre-combustion Chamber Inserts  (Read 14518 times)
August 19, 2015, 06:24:27 pm
« on: August 19, 2015, 06:24:27 pm »
I just received eight new 1.6TD pre-combustion chamber inserts in the post today.  They were a challenge to get.  I got them from a company called Engine Parts UK.  They will not sell to people in the US.  In fact, they require that the parts be sold to the person who pays for them which complicates things a bit more.  The end cost was $225 for the 8 inserts, so $28.13 each to the door.  A bit pricey, but a whole lot less than a wrecked engine.
Reply #1August 19, 2015, 08:56:33 pm
Re: New 1.6TD Pre-combustion Chamber Inserts
« Reply #1 on: August 19, 2015, 08:56:33 pm »
Dimensions appear to be perfect.  They have them for the 1.6 non turbo and the AAZ also along with having them oversize.
Reply #2August 20, 2015, 05:42:10 am
Gizmoman
  • 1301
« Reply #2 on: August 20, 2015, 05:42:10 am »
Thanks for the update on your efforts libby. I hope I never need them for my AAZ but if I do. . .
Until I fix my transmission, there's little worry of my inserts going South ;)
Reply #3August 20, 2015, 07:42:09 am
« Reply #3 on: August 20, 2015, 07:42:09 am »
What are these made of? I prefer steel over Inconel is why I ask.
Reply #4August 20, 2015, 12:42:21 pm
« Reply #4 on: August 20, 2015, 12:42:21 pm »
They are magnetic.  I can't really say beyond that.
Reply #5August 21, 2015, 04:36:34 am
« Reply #5 on: August 21, 2015, 04:36:34 am »
very good news
Reply #6August 21, 2015, 05:45:50 am
« Reply #6 on: August 21, 2015, 05:45:50 am »
The magnetic ones are the ones I seem to like. The non magnetic *assuming Inconel* are what let loose on my head. Seems like they grow too much for the aluminum.
Reply #7August 21, 2015, 07:41:51 am
« Reply #7 on: August 21, 2015, 07:41:51 am »
Apparently certain inconel alloys are magnetic and some aren't (as is the case with stainless).  My understanding is that it depends on how the iron atoms align within the metal.
From a small and inconclusive study, I have found that the inserts that are magnetic are less prone to cracking.
It will hopefully be years (or forever) before I know whether or not these ones crack.   :)
Reply #8August 21, 2015, 09:36:37 am
« Reply #8 on: August 21, 2015, 09:36:37 am »
do you have part numbers?  is this the right site? http://www.enginepartsuk.net/
i have a friend that bounces all over europe and will be in the uk later this year so i plan to order a set or 2.
Reply #9August 21, 2015, 03:41:11 pm
« Reply #9 on: August 21, 2015, 03:41:11 pm »
That is the company.  If you go to their catalogues and EP Valve Train PDF it opens this linked catalogue.
http://www.enginepartsuk.net/sites/default/files/epcat2013.pdf
The vw pre-combustion chamber inserts are on page 244 and 245.  Their in-house part # for 1.6TD std size inserts is VWPCC795000STD.  Their measurements correspond to the actual parts, but many of the engine codes are wrong.  Obviously the AFN, 1Z, AHU etc do not have PCCs....  Best is to knock out an insert, measure it and get the correct part based on size.
It looks like the part# VWPCC765000 is the OS for the 1.6 non-turbo.  I wonder if they stock a VWPCC765000STD for standard size 1.6 non-turbo inserts.  VWPCC795002STD would be for standard size AAZ PCCs.
« Last Edit: August 21, 2015, 03:45:44 pm by libbydiesel »
Reply #10November 13, 2015, 11:05:13 am
« Reply #10 on: November 13, 2015, 11:05:13 am »
do you know the part numbers or how to order the over sized ones?
Reply #11November 13, 2015, 02:41:47 pm
RustyCaddy
  • 395
« Reply #11 on: November 13, 2015, 02:41:47 pm »
Don't know if this helps as far as the original VAG numbers but have two sets here: 1) set roughly the same dimensions (slightly larger) to the VWPCC795000STD insets is in a bag labeled VW #068-103-391 (another associated number on the bag is 16-9024), but i believe might be for a 1.5 NA since it is a 068 prefix with no triangle stamp and the other 2) set is VW #069-103-391 (with two other part number 16-9023 and Mctelli 120019) so the right prefix for a turbo diesel (or the bag was mislabeled 069 somewhere?) but its size corresponds to a slightly oversized (but maybe that is because of the plastic bag wrap) VWPCC765000 insert and it has no triangle stamp.
Rereading this may be it just confuses things.
Not meaning to hijack now but does anyone know if the 1.5 precups are strong enough to use in a 1.6 turbo (since the standard size would fit)? Don't really see the point of using them for a 1.5l head rebuild.
« Last Edit: November 13, 2015, 02:43:51 pm by RustyCaddy »
Reply #12November 25, 2015, 06:39:17 am
jmaddocks
  • 75
« Reply #12 on: November 25, 2015, 06:39:17 am »
Pulled the head off our 1.6 to port it and discovered all the PCs are cracked.  :( I can't in good conscience put it back together like that, esp. running 30+ PSI.
Hope this isn't a threadjack... I have a request into Eurocar (in Italy) for a quote on new PCs.  Has anyone successfully gotten new PCs through them?
One of the other options I'm exploring is getting a used AAZ head, but I'll likely be in the same predicament with needing new PCs.  Has anyone successfully procured AAZ PCs through NAPA?
TIA
'89 Jetta 1.6d HE200WG, ported solid lifter head, ARP studs, FMIC, 2.5" exhaust, lightened FW, ACT clutch
'79 Rabbit ABA swap, microsquirt
'91 Corrado 1.9L T3/T04e, ported 16v head, JE pistons, Scat rods, megasquirt, peloquin, E85, etc
Reply #13November 25, 2015, 08:52:05 am
« Reply #13 on: November 25, 2015, 08:52:05 am »
TIA
here is the napa part number ATM 028103391M
i can't tell if they are available or not, it looks like there is only one available in denver...
Reply #14November 25, 2015, 08:53:32 am
« Reply #14 on: November 25, 2015, 08:53:32 am »
remove the atm from the part number for the vw number
