Author Topic: Opinions on CV axles  (Read 3498 times)
January 18, 2015, 07:42:28 am
92EcoDiesel Jetta
« on: January 18, 2015, 07:42:28 am »
Both my axles have outer CV boot issues where grease is spilling out. Left boot has a hole from heat damage (from a shop that used oxy acetylene on the outer tie rods when an alignment was done which also ruined the tie rod boots). The right CV boot has a missing clamp. The car drives fine and I do not hear any noise from the CV joint yet. My high freq. hearing is very poor and I may not hear the noise from the CV's if present. What are some ways to diagnose the outer CV joints without removal?
Anyway, I bought a set of FEQ axles $66 ea. Pic below is the passenger side axle on the bottom and a spare OE VW axle on top. As you can see, the OE axle shaft is quite a bit bigger in diameter than the FEQ (same with the driver side axle). Do you think there is an issue with strength with the smaller diameter? If the small shaft is too flexible, would that cause the CV joint to wear prematurely? I am wondering if I should install the new axles or just reboot/ re-grease my old axles? Your thoughts?
Reply #1January 18, 2015, 02:37:38 pm
Re: Opinions on CV axles
« Reply #1 on: January 18, 2015, 02:37:38 pm »
Constant Maintenance axles?   Glad so many people have them.
First look for a hole in the boot.
I  jack one front  wheel off the ground, then hold the shaft wile rotating the ends,  if there is rotational play, replace.
That big one is probably hollow and 3% lighter.
I never   rejoint them, just  get a lifetime one and replace as needed, it's faster and not as greasy.
Reply #2January 18, 2015, 03:05:09 pm
92EcoDiesel Jetta
« Reply #2 on: January 18, 2015, 03:05:09 pm »
Thanks! These are lifetime axles (China), hope I never have to use the warranty. What's the pros/ cons of undoing the ball joint vs undoing 2 strut bolts to get the axles out? Will camber be disturbed?
Reply #3January 18, 2015, 03:15:05 pm
« Reply #3 on: January 18, 2015, 03:15:05 pm »
If the three bolts that attach the ball joint to the control arm are loosened, camber can be affected.
The single pinch bolt on the knuckle for the BJ stem, or the two strut housing bolts... no worries.
I often do the strut bolts, because they're slightly easier than pushing the BJ stem outta the knuckle. (6 or .5doz) YMMV
Reply #4January 18, 2015, 08:19:58 pm
air-cooled or diesel
« Reply #4 on: January 18, 2015, 08:19:58 pm »
loosening the strut bolt(s) will change camber. you need a machine to re-align. the single bj (stem) bolt/nut and a pry bar; that is if you need to to get space to cleanly remove axle(s).
i find even boot kits for some cars to be a lot more than swapping complete axles. if your boot (&etc) are gone; its easier to replace whole axle; ive in the past referbeshed cv's. but joint is usually gone enough to where its easier and more cost effective to swap. i replace on a regular basis(like 5 or so years).
Reply #5January 19, 2015, 02:27:46 am
Toby
  • 728
« Reply #5 on: January 19, 2015, 02:27:46 am »
"loosening the strut bolt(s) will change camber. you need a machine to re-align."
Not if you mark them.
« Last Edit: January 19, 2015, 02:30:27 am by Toby »
Reply #6January 19, 2015, 04:14:28 am
« Reply #6 on: January 19, 2015, 04:14:28 am »
MK1s had the eccentric bolts and slots, MK2 strut housings are not slotted and go back together in the same place.
Edit: Bentley indicates a special, narrow eccentric bolt can be used; so if you have all standard bolts, no camber worries... If you have an eccentric, just mark its position before removal.
« Last Edit: January 19, 2015, 04:55:34 am by TylerDurden »
Reply #7January 21, 2015, 10:57:04 am
scubagli
  • 18
« Reply #7 on: January 21, 2015, 10:57:04 am »
That is totally false, I've owned 8 mkii's, everyone had between 3 and 6 degrees of camber adjustment.  With stock bolts...
Reply #8January 21, 2015, 01:38:45 pm
92EcoDiesel Jetta
« Reply #8 on: January 21, 2015, 01:38:45 pm »
I remember having to buy a camber bolt (old one snapped even with lots of penetrating oil) on my 92 Jetta when I had to replace one of the struts a few years ago. I'll be paying someone to do the axles (on a lift) soon. Too damn cold outside DIY on the ground.
Anyone here measure and adjust their own camber? I have an easy and accurate way to adjust toe but never tried camber.
Reply #9January 21, 2015, 06:48:59 pm
« Reply #9 on: January 21, 2015, 06:48:59 pm »
« Last Edit: June 15, 2015, 04:07:40 pm by TylerDurden »
